Well, it looks as if my problems are solved (at least the running above idle one). I got new HP and LP filters from Marc at Wefings and decided I'd try a couple more things before I installed them.
I had previously taken out the fuel flow turbines and got some advice that the primer bulbs were not really needed. So, I took the primer bulbs out of both fuel lines and (after making sure they were free of debris and spinning well) reinstalled the fuel flow turbines. Both engines run well now at all speeds. I suspect that the primer bulbs were somehow restricting fuel flow above idle, at least on the Port engine.
Now, the only remaining issue is a pee hole problem on the Starboard engine. I've run three treatments of salt-away through both engines. The upper flush port connects somehow with that pee hole and on the Port engine, water freely flows out of the hole when flushing. On the Starboard engine, no flow no matter what. It doesn't overheat so I suspect some sort of obstruction. According to the manual, that tube connects directly to the block. I've run a wire in about 9" and there is no obstruction that I can find. I had good flow up until about a month ago. Maybe I need FloMax... :roll:
Next step is to use my air compressor, dial it down to about 20PSI and try blowing it up the hole/tube. If that doesn't work and it's still not overheating, I'll leave it until I haul for an oil change and can get the side cover off. If anyone has any other ideas I could try, please send them on!
