Discovery
Active member
- Joined
- Dec 8, 2003
- Messages
- 1,245
- Reaction score
- 0
- C Dory Year
- 2006
- C Dory Model
- 255 Tomcat
- Hull Identification Number
- CDO25510J506
- Vessel Name
- Discovery
Can't stand not to be working on the boat, so I added a couple more modifications to Discovery.
The AC switch panel has been a problem in the past. Occasionally the switches get switched by peoples feet, or placing things on the floor under the dinette. More than once, I have thought I was charging the batteries, when on shore power, only to realize the switch had been inadvertently turned off. Fixed that! I covered the panel with a 1/4" piece of plexiglass, spaced out 1". Just enough room to get a finger behind to throw a switch, but only if you intend to.
I also built a bait prep/filet board. It is made from 3/8" and 3/4" starboard type polyethyelene plastic. It's mounted on a Scotty Rail mount base. This cutting station will also double as a place to put things when cooking on the Magma BBQ Grill, which mounts to the left.
