Hi Gurus, I started my C-Brat membership with a thread on the CD25 vs the TC. I thought I would push my luck and see if you would tolerate some more newby questions but I chg'd thread names to more accurately reflect the content. I am leaning strongly towards the TC but have not completely ruled out the CD25/Venture26.
I have some engine questions re. the TC as I will be looking for a used boat/package. I searched around a little and got some info but still have some questions:
1) It seems most TC's have twin 150hp engines, some have 135hp and 140hp plus likely other sizes. Is the 135hp vs the 150hp difference significant other than top speed? Or, for example, is it worth a significant amount of money to get 150hp engines vs 135hp engines? I believe I want 4 cycle engines.
2) Are engine vintages significant? Older engines have carbs, newer have fuel injection -- the later is likely better, are the carbs OK? Have some vintages of some specific brands been troublesome or had high problem rates?
3) Are all brands (Honda, Suzuki, Yamaha etc.) available with counter rotation? If not, is it a big deal on the TC hull to not have counter rotation?
4) How does the TC perform with one engine not operational. Will it plane? Does 150 vs 135hp make a difference when running on one engine?
5) How slow will the TC run with one engine for trolling purposes. Can it get down to about 2mph -- or is a kicker motor needed for trolling for salmon etc.?
6) System redundancy: are the systems feeding the two engines on the TC truly separate (batteries, wiring, fuel tanks, fuel lines/filters, etc.)
I have seen many twin installations (my experience is with inboard engines) where electrical and/or fuel components have been shared between the engines so you don't have the complete advantage of redundant power. I am hoping the TC is rigged or at least can be rigged so that any one failure will leave one engine running and usable.
At the risk of over-staying my welcome, I will stop the question list. Thks again for all your valuable help. Ed
