Teak Helm Hubs
Alyssa Jean
Active member
Nov 2, 2003
2,377
2005
Alyssa Jean
I just finished turning 8 more teak helm hubs to replace the black plastic stock hubs that come with the helm wheel. PM or email me if you are interested in obtaining one. $18.00 includes S&H.
Which models would they fit? A 16? Do you have an inside diameter for the wheel center?
David, if I supplied the Hawai'ian Koa wood, would you be able to replicate one of those, [should the need arise]?
They won't fit the older 16's helm. I had to make a really custom one for mine. They fit any of the stock helms that CD uses that have the black plastic cone looking hub insert. I don't remember the name brand of that helm, but they are used in Bayliners and other boats as well. The hole that it fits into is 2 3/8".
Koa. I would need a piece a minimum of 1" thick (1 1/4 would be better) and a minimum on 3" sq. Send me enough to do two so I can make on for me also. I love the look of Koa. I can switch off every other month with the Cocoboa Rosewood one I have installed now. But to answer your question, I would love to make you an replacement helm. That is JUST in case you buy a certain 25 that you have money on and can't wait to find out whether it is a go or not. Just in case.
Hey Matt- check around the back of the shop for some of that Hawai'ian Koa wood.
MartyP
That's awesome, David. Mahalo.
I'll look around and see what scrap blocks I [may] have in that size...just in case. :wink:
I know I've got some other hardwood from Fiji; really hard/dense and dark with black grain running thru it. Very nice.
David,
I modified one of your standard helm hubs to fit my 87' 16' Angler wheel without much trouble. Cut/sanded to fit over exisitng hub secured with 5200. I didn't have to cut around the outside, only the backside which doesn't show. Wish I had a picture.
JT
Hey Guys, just in case you don't find the Koa you might need let me know, I just may have a few nice pieces left over from the pallet of blanks we brought over from Honolulu last month.... just in case you need some of course. Let me know and I can slice a few blocks off for making hubs.
Ron
David I would like one. I can not find your message box (large data base).
I have been making paddles lately and the local sources for teak tell me teak is 4 times the cost of most normal types of wood. I'd would like the teak. I would also like to find a supplier for exotic woods. My sources are at least 100 miles away.
My boat is 2006 22' angler with the normal wheel.
Thank you
my email jac467h@gte.net.
Jeff
Well, one of David's helm hubs has made it across the country to Connecticut arriving in this afternoon's mail. What a work of art and a wonderful addition it will be to C-Star. Thanks, David.
I had someone else email me about the helms these fit. The helm that C-Dory has been using for quite a while is made by Sea Star and has a black plastic hub in a 2 7/16" center hole. The hub is held in place with a small set screw.
