texasair
- Joined
- Jan 31, 2009
- Messages
- 410
- Reaction score
- 0
- C Dory Year
- 1989
- C Dory Model
- 22 Cruiser
- Vessel Name
- Bixby's Cub
I have removed all of the teak and teak grab rails from the 89 22 cruiser that I am putting back in seaworthy condition. I have removed the little trees growing on the grab rails. Next is a good sanding. I am inclined to put on 5 or 6 coats of marine polyurethane with the first coat to be thinned for penetration. The boat will spent a total of 2-3 months a year on the water and the rest of the time will be stored inside. Do the brats concur?...or should I just oil the wood?
What a project... This boat sat in an open yard for 6 years with perhaps the last 2 years in a nose down configuration with a foot of water in a closed cabin in the south Texas sun. Talk about mold, mildew and corrosion. I am stripping the entire interior to facilitate cleaning, some of the interior is rotted and will have to be replaced. I found these brackets to replace the OEM ones that had completely rusted out. (http://www.greenboatstuff.com/seadogstst90.html) The good news is that the hull seems to be sound and both motors have good compression. Hooked the 15 up to a gas can and it started on the first crank, no water pumping and shifting frozen, but I can fix that.
The 70 needed a new power pack to fire off, but all 3 carbs are gunked up and will need a rebuild and it will need a new water pump. Both motors have most of the paint flaked and corroded off, I will scrape sand and repaint only after I know they are both back in top running condition.
I am determined to have it back together and running for Lake Powell in Sept. I have decided on the new name.. "Bixby's Cub".
Tex and Sharon in Cypress, Texas where it is going to freeze tonight ...again. But my shop has a big heater.
