Well-known member
- Joined
- Oct 2, 2011
- Messages
- 5,143
- Reaction score
- 92
- C Dory Year
- 2009
- C Dory Model
- 25 Cruiser
- Hull Identification Number
- UWH25301J809
- Vessel Name
- C-Traveler
Just a heads up. I may have to cancel my trip to the Tennessee. It was a bad day at the lake for me today. Having shift issues with the main again. Earlier I was experiencing ratcheting or grinding gears when trying to go into reverse if going forward more than just a few miles an hour, but less than 5mph. I thought I had that fixed with the replacement of shift and throttle cables, and tightening down the one screw that holds the shift shaft bracket. In fact, I think it was that lose bracket. Outboard worked fine after that on a short test on a local lake. Kicker throttle cable was getting stiff, so just replaced both it and the shift cable on the kicker. It's now working great! Went out to the lake today, as it was a nice day, just to run everything and enjoy the day. After going thru some weeds while going forward at around 5mph, I slammed the remote control into reverse to clear the engine, and all I got was ratcheting and grinding. And can not get reverse at all now. Just the grinding of gears. Reverse had worked fine backing off the trailer earlier, even at full throttle (I was on a shallow ramp). After that, I noticed that the remote was more stiff going throttling up going forward. And the shift cable was off skew again as shutting the engine down and restarting it I got the warning light for an improper neutral position. The shift shaft bracket actually felt secured when I reached in to see if it was loose. However, I notice that there is a lot of up and down play. So that's a problem that I will need to resolve/fix before the boat goes out again. My day of troubles didn't end there. Heading home, I had a moving truck driver get my attention, and talking (yelling) between us while going 45mph down the street, all I could make out was that my tire came off... I slowed down and took the next exit. Sure enough, my right front trailer tire and wheel were missing. I never felt a thing. And as luck would have it, I did not have my TPMS turned on for this short jaunt from home. Otherwise, maybe, just maybe, I'd be able to go back and find the tire & wheel. At least get the hub and see if it gave me any hints as to what happened. And retrieve the TPMS sensor off that wheel. I've gone back twice to look for it, but the area where the trucker motioned to me was next to a woodsy area and next to walking through that area, fat chance of seeing the tire from the roadway. I had just checked the oil in the oil bath bearings last night, and all looked fine. If the bearing had seized, I think I would have seen smoke or fire, or felt the trailer drag on the truck. No such thing happened. And this was within just 3 or 4 miles of the boat launch, where I know the tire was still on! Fortunately, I think my spindle is still ok. I had a helluva time getting the castle nut off, and then had to pound on the part of the bearing cage that sits on the spindle, for both the inner and outer bearings, so it appears those were stuck on. I am thinking now it's quite possible I had some salt water intrusion into the hubs while launching and loading out west. I haven't seen any indication of the inner seals leaking, but do get some seepage of oil from the fill hole seals in the cap, which means there has probably been some water seeping into the hubs. Although I always let them cool off before dunking. Guess I'll be pulling all the hubs off and checking the bearings and oil while waiting for new parts for the one. I should be able to get the boat trailer back into traveling status within another week, but not sure what's up with the shifting on the main. If that has to go to the shop, Tennessee is definitely off the books, and my boating season is done. If I can find the issue and get it fixed, then I'm still on. I'll make my decision by the end of the month.
