Ken O
- Joined
- Mar 5, 2014
- Messages
- 129
- Reaction score
- 1
- C Dory Year
- 1990
- C Dory Model
- 22 Cruiser
- Vessel Name
- Ravens' Roost
My tach shows zero RPM. Engine is a Honda BF90A, tach is a 7000 RPM Honda/Faria. The ground at the tach tests good, the positive at the tach tests good, and the engine shows good charging voltages when running. The dial on the back of the tach is set to "1" which should be correct for this engine. The tach didn't work when I bought the boat. How can I test the gray wire to see if the problem is tach, wiring harness, or engine?
