Well-known member
- Joined
- Nov 2, 2003
- Messages
- 21,963
- Reaction score
- 298
- C Dory Year
- 2007
- C Dory Model
- 25 Cruiser
- Hull Identification Number
- DOR25652A707
- Vessel Name
- thataway
I am going to share the information forewarded to me by the "engineer" at C Dory:
"There is approximately 22” of height between the top of the tank and the hull side vent fitting. This height can not be increased. It seems to me that Mr. Austin’s problem is indeed caused by fuel expanding in the tank. When a boat is in a lift it will receive reflected sunlight from the water on the bottom of the boat which will heat the fuel tank to a temperature much higher than if the boat were in the water, on a trailer or in a rack. Please note that 24” of 5/8” fuel line will hold only .032 gallons of fuel, not much. Mr. Austin must be made aware that the tanks can not be completely full when the boat is on the lift. He is correct to have the boat stern down when in the lift.:
My comment: although .032 of a gallon of fuel does not seem like much to him--it is over 4 oz--and there have been a number of times that fuel has come out of vent line, which means that more than four ounces is being pushed up into the vent and any excess overflows.
He is absolutely wrong about the sunlight reflecting on the water for a number of reasons, the most obvious is that when the boat is in a lift, there is no sunlight reflecting off the water, because the boat is less than a foot from a deck, with a 6 foot sea wall, so that virtually no sunlight gets to the water at any time under the boat. The heat is caused by the sunlight on the hull direcly. This same event can occur on a trailer, unless there is a specific defect in my tank vent.
I am also told that due to miscommunication the cushions and back cover were not sent. But there is this warning from the engineer:
"Beyond being unsanitary, the gap between the counter and fiddle will create mildew in the hot and humid climate found in Florida. This becomes an esthetic and rot concern as well. Carpentry and QA must be made more vigilant."
So now I am really curious as to what I will be getting and how I can make it more "Sanitary".....
On the positive side--we have begun to lay out the navigational instruments and start hook up there.
