The old debate, twin engines versus one engine on a C-Dory
I know this will spark a lot of controversy, but I could not help passing this along as it confirms what I have long thought but had no hard facts. This month’s Powerboat Reports (March 2007) tests the performance of a single engine (225 hp) versus twin engines (115 hp) on an identical 23 foot center counsel. The two engines even had a 5 hp advantage. All the engines were 4 stroke.
They found (1) significantly higher noise levels with two engines, (2) worse fuel economy with two engines, (3) slower at WOT with two engines, (4) two engines always operated at higher RPMs for the same speed as one engine, (5) more weight with two engines, (6) more upfront costs with two engines, and (7) more ongoing maintenance costs with two engines. Bottom line, the single delivers better performance at a lower price.
I believe these findings would hold true for a 22 and 25 foot C-Dory, though I am sure that many of you will not agree with this. I know there is a big COOL factor with two engines that I cannot deny. Just realize that there is a price to pay for it.
Also I know that there is the redundancy safety argument of twins, especially offshore. However, with the increased reliability of todays’s 4 strokes, the appeal of twins as a backup has lessened to a great extent. Also, a kicker is an option with one engine.
Finally, I realize that those with counter rotating props may argue that there is a handling benefit of twins around the docks and maybe in rough water. I would argue that the C-Dory is relatively light and maneuverable without twins. In rough water slow down or use trim tabs for control.
In the end, folks get what engine configuration they prefer. But I thought there were a few facts to shed on this argument.
An interesting test would be with a 90 + 15 hp trolling motor vs twin Honda 50s
The 90+15 weighs about 480.
Twin 50s (40s too) weigh 410.
Anyone with fuel flow meters and a single, no trolling motor, want to do a test with an extra
120lbs on the transom vs. not?
Mike
Mike
I'm not sure how many c-dory's are using a 15hp kicker. I have the 90hp main and the 8hp classic.
what's the weight on that paddle? there's no way you can justify any boat related expense...the bottom line is, get what ya want.
A main and a kicker does somewhat negate the weight and maintenance expense issue
Tom... How many cans :beer :beer per hour does that paddle burn and how often do you change the oil???
Forgive me... but is not one main motor and a kicker ...two motors? :smileo
Yep, toss of the coin... each time I get ready to rig a boat I go thru this...changing my mind sometimes... like the 18 Angler I now have.. Bought it with one OLD original 84 modle Johnson 2 stroke...and before I put it in the water, I added a "portable" 9 hp new Suzuki 4 stroke...and bingo I was correct... about 1/2 mile across a large area in Lake Martin, wind blowing the wrong way, no one else on the lake with it so cold..and getting dark... that old Johnson gave up the ghost...and I was really glad I had a kicker...or....second motor.
Then, a week later, after removing that "portable" new motor so no one woiuld still it.... as I was bringing it back down the steap concrete walkway...the hand truck helping me toat that "portable" new motor hit a rock, forcing a hard immediate much faster than me pivit to the right, slinging me...and my new "portable" motor to the ground...with me in a very stupid man move....making sure my new "portable" motor landed on me instead of the concrete. ... :crook :cry When I got enough air back in my body to cry... I did. Then got up, and once more, finished the trip with the portable motor. ....and a few weeks later, bought a non-portable 50 hp suzuki..... and sold that chest chrushing, ego killing ya aint as young as you use to be "....$&^%%$^&* portable kicker.
Back to one motor.
Now.. looking at powering a new hull...and back to twins....both NON-PORTABLE. Cold day in August in Alabama before Byrdman buys another, "portable" kicker.
Byrdman
Mike
Doesn't change the question much. Subtract ten pounds. My question
is: weight or drag or both?
Mike
We have been delighted with our single. However (and there's always a "however"), I do like the look of twins on the back of these boats.
Also, Brent and I did have the chance to try out the "paddle" solution one evening. While anchored out, we rafted up for the evening... to converse, eat, and toast the day's events. During that time, the boats rotated through 360º, wrapping our anchor lines. We paddled the boats (sure could have just motored around, too... but we were just messin' around) back around before we unrafted for the night. Nice that the water was clear so we could see exactly what was happening with the rode. Surprisingly, it wasn't that tough to move the boats with the paddles... not that I'd want to do it any distance or against a wind or tide. :wink:
Jim B. (still on the road, wishing we were still on the water)
Jim I believe each point made in the article is correct. These are the same points that Les Lampman (most eloquently) made on this very board a couple of years ago. Okay maybe three or four years ago on the C-Dogs but that discussion is preserved on this board. Of all the points the most significant to me is the noise factor. I would like quieter than I get running twins. Less cost and less maintenance is good also. You can probafly add in greater durability, benefits of fuel injection (in some lines), more room for swim step, more room for downriggers, and several other advantages to the large single engine.
On the other hand -
I like the look of twins from inside the boat, they are lower and block less of my view astern yet I can still see them fine for making sternway. I troll a lot and all too often in fair sized waves, a single 40hp is a dandy trolling engine in those conditions, a kicker is a little underpowered when it's rough. Twins give some lateral stability. Twins, particularly with Permatrims or some other hydrofoil give you many of the benefits of trim tabs without having trim tabs. Twins can be run one engine at a time when just moseying along, (when inland or exploring shallows, etc.) particularly if you have an electrical set up so that either twin will charge the house battery as well as its dedicated start battery. I don't race anyone in my C-Dory so top end doesn;t matter. I think the safety factor is mostly mythical with twins on 24 inch centers. Like they say its gonna be the gas or your're gonna hit something that takes out both props or lower units.
In short I got twins this time around. Next time I might get a single just to try it out. Or better yet get the cat and not worry about it. But wait that new 28 has that spiffy inboard - oh boy.
My boat comes out of the barn in five weeks, I am getting a little giddy.
Regards to all,
Mark
PS Jim - always appreciated those rpm studies you did and never said so at the time, thanks.
Jim,
As you know I have twins and really like them, always had singles before. Noise factor, hmmm, I don't find that a problem at least with my twin Yami 80's, but then again I haven't compared against another CD25 with a single.
I believe Chris (Rana Verde) did a calculation on the twin fuel consumption of one CD22 (El and Bill's?) and his CD22 on last year's Alaska trip, virtually the same. So bottom type and loading could be a definite factor on these measurements. I'd believe the twins use slightly more gas, but not significantly.
I've run into seaweed a few times in weather and was sure glad I still had one engine moving us along while the other was cleared by shutting it down and tilting it to let it just fall off -- without even getting out of the cabin! Sure, not much, but I can see where things could turn difficult in a short time.
Like you said, to each his own, either can justify the usage of twins or singles by simply emphasizing one aspect or another. Thanks for the info.
Just to stir the pot a bit -- I am considering setting Lori Ann up with triples :o Actually, not, more like 2.2 -- the 2 Yamaha 150s and a Yamaha 8 in between them for trolling. However, I am going to give myself one good season with the twins before seriously thinking about the 2.2 option. I am not sure whether I can steer the 8 with the autopilot and have it tilted up independently of the 150s so it is out of harm's way.
C-Dory boats are used in far to remote places and over to great a distance for anyone to be without the safety and reliability factor that total redundancy gives in all systems and can be called on in a moments notice should either of the engines fail to perform as they likely will, so the the wise mariner in the C-Dory environment should make the judicious choice of twin engines, or a single Mercury. :mrgreen:
Thataway has the 2.01 engine option. We have the 3.5 hp dinghy engine bracket, which mounts on the railing, fitted so it will slip into the dive ladder bracket and push the boat at about 3 knots. (See Picture #76/99)
This is probably not strong enough for an 8 hp, but the concept might be expanded for a larger motor.. No auto pilot, but it will tiller steer the boat with the main engines up.
I had an impeller go out in the San Juans. I have twin 40's which allowed me to cross Rosario Straights and return to where my trailer was waiting. I would not have wanted to attempt that crossing with a kicker which would have meant finding a place to do the repairs in the Islands. Deer Harbor would have been the closest to where the impeller went out. I don't like the extra maintence costs of twins but I sure like the insurance factor.
Steve (Dora Jean) --
Yep -- we have cruised many a pleasurable mile with Chris, on Rana Verde. With his single Yamaha and our dual Hondas we come within 1% (either way) on our fuel consumption at the pump.
We prefer the duals because I'm not a mechanic (Chris is!). When we replaced our twin engines, we replaced with dual Hondas -- safety factor for us in remote areas (we've needed it a few times -- and it makes for some good stories). And, when one engine died (of old age) in the Chesapeake and there was going to be a delay of several months to replace it (at a reasonable price) we simply trailered off to the Erie Canal (with its many speed zones) and rode around those months on our single 40!
This debate, however, seems to miss the other central themes of life: Should our truck be a Ford, a Dodge, or a Chevie? Or, if we are going to carry a firearm, should it be a .30-.30 or a .270? And, what's the best way to brew a good cuppa java?
I've always liked my single and kicker arrangement. It's always made sense to me that it is easier maintaining one big engine rather than two. We've used the kicker and were able to get back in small chop with no problem using the 9.9 hp kicker.
However... I did pause to think during our rough water experience last weekend what would have happened if our very strong and reliable motor somehow stopped working in the midst of all that. I'm sure that the kicker would not have been able to handle those seas. I'm thinking that I would have had a lot more confidence running on a single 50 hp if the other went out in those conditions.
In fact, I told Caryn that if we ever got a new boat, I might think about getting twins the next time. Just food for thought.
Peter
