http://oceansignal.com/products/mob1/
Saw this for sale on Fisheries Supply e-mail. I had never seen it before. Opinions?
hardee":2ztw4gz4 said:My first thoughts were as I noted earlier in this thread, but in talking to the guys I learned it is programmed to your own boats MMSI so it sends the Emergency AIS signal to your boat automatically. If you are able to do a manual operation, you can switch it over to an all points AIS Emergency to broadcast to all AIS receivers with in the transmitting range. That may not be very far. It could be only a mile or two, or maybe up to 5 miles in optimal conditions.
Sure wish this device and the ACR PLB could be combined. That would give 3 functional calls: DSC, AIS and NOAA SAR. With that kind of a broadcast net, somebody should hear you.
"I am not saying that under some circumstances it might not be a good idea. Because it could be. We carry the PLB on our persons, when at risk...but would not set those off in a simple MOB situation."
A Man Over Board AIS transmitter is only intended for short range signalling to an AIS receiver installed onboard your own vessel. It will not directly alert the emergency services or any other vessels.
As far as transmitting the distress further:
Actions on Receipt of a Distress Alert
Ships receiving a DSC distress alert from another ship should normally not acknowledge the alert by DSC since acknowledgment of a DSC distress alert by use of DSC is normally made by coast stations only.
Only if no other station seems to have received the DSC distress alert, and the transmission of the DSC distress alert continues, the ship should acknowledge the DSC distress alert by use of DSC to terminate the call. The ship should then, in addition, inform a coast station or a coast earth station by any practicable means.
A coast station which receives a DSC distress alert will immediately send an acknowledgment. The sending device will then both stop repeating the alert, and tune to the designated channel for the distress message to be sent. Ships receiving a distress alert who are outside coast station range or do not receive an acknowledgment, are required to relay the distress alert by any means to land.[9]
Harvey, in your case, your boat is going to blithely continue on its way. It may beyond range by the time your beacon transmits. The chance of another boat being close enough I believe would be small. You are far better to just have the EPIRB..and not try and rely on the AIS/DSC transmitter.
