TOGO
- Joined
- Sep 2, 2010
- Messages
- 91
- Reaction score
- 0
- C Dory Year
- 2009
- C Dory Model
- 19 Angler
- Hull Identification Number
- CD019157F809
- Vessel Name
- TOGO
I tripped two 50 amp thermal breakers simultaneously one goes to the switch panel the other to the windless. This happen tried to drop the anchor and nothing, did not even make a sound. I then noticed no VHF, no GPS, and no sounder. I know that the sounder was working as we were looking for about 20 feet of water.
I reset the breakers after I discovered that it was the little lever not the red button that resets. What is the red button for? I did notice that one of the battery terminals was a little loose and took care of that. Yes I will change the wing nuts to lock nuts.
The windless and the and all electronics are working like nothing happen. Could this of been caused by the loose battery terminal? Oh it had been a few months since I had used the windless. The boat is used at least once a week from a trailer.
I will appreciate your comments as I not sure what caused the failure and that is not a good feeling.
Guy
Guy
