Thisaway
Well-known member
Nov 2, 2003
21,766
116
2007
25 Cruiser
DOR25652A707
Full circle: Back in the late 70's when I first saw a C Dory 22, I vowed that I would buy one when I got to the point when I could no longer sail. We bought "C Pelican", a 1992 C dory 22 cruiser for use on the West Coast. That lead to Frequent Sea--a C Dory 25 to replace that boat when we had the Tom Cat in Florida. A few months ago, I thought I could continue life without a boat capable our staying over night on. We had owned such boats continuously for 50 years. Well, I was wrong. I have to still have that "dream" of doing some cruising. Not when or where--but now we have "Thisaway". I gave Charlie the name "Thataway"--and it is his.
So I will go thru our thought process and what we are doing as we fix up a nice 2006 C Dory 22, with a Honda 90. Ideally we would like an injected engine--this is the last of the 90 hp carburetor engines.
We found that we didn't tow the Tom Cat--and even the 25 we had to have a specialized truck. We can tow the 22 with my Honda Pilot. (We have experience doing this with C Pelican). We are also going to attempt to tow the 22 behind our RV....the problem may be the length. I see rigs which are over 65 feet all of the time on the road. I don't know the overall length of the rig, until we hook it up--but most likely the trailer frame end will not be more than 65 feet from the front bumper of the RV to the back of the trailer. Current plan is to take the boat to AZ early in the summer--perhaps a few days a Powell. Then off with the grandkids for a couple of weeks, then back to AZ and pick up the boat--and back to PNW. This winter we hope to spend some time in the Keys, with both the RV and and C Dory 22. We will have to drive the Pilot--so two vehicles.
The boat is generally in good shape. There is a new prop--and the one which is slightly dinged (will be repaired). There is a Coleman stove (I am not keen on cartridge type stoves in boats) We are considering an inductive cook top. (Powered by Honda Generator)--also for heating a small electric heater if necessary. The boat came with a small window air conditioner. That will be what we will use (as we did in the 25). No refrigeration--just ice chests.
We have a 4" Garmin combo sounder and chart plotter. I also have a 5" Garmin Chart plotter on the Caracal--and will put a second mount in the 22 for it.
There is a VHF radio, and I will add a second Standard Horizon with AIS capability. At this point--no radar, but I may buy one of the first mate FLIR image systems.....(We are more likely to run after dark--than in fog).
As we noted in the "Mystery Man" thread, the boat was bow heavy....well I may have just found out one of the reasons. This evening, I needed some chain to secure the door (the lock is broken)....well there is at least 100, and maybe more... of 1/4" coil proof chain in the anchor locker--and I didn't seen any rope rode! Fortunately I had bolt cutters, so I was able to padlock the door to secure the boat at the hotel parking lot....
Enough for tonight--this has been a whirlwind. We made the decision to buy the boat about 4 days ago--I have so far driven 1500 miles, and had a day of respite at Charlies--and now about 400 miles from home!
At Charlie's we determined the best way to move the axle is to jack up the trailer with the boat on it until the wheels were off the ground. (This was a torsion axle. As Charlie noted we were sure that there were new tires (Thanks to the seller Chris)--and we made sure that the trailer was level. After loosening the "U" bolts, and then used a 3# hammer to tap the axle forward.
Any suggestions would be appreciated. Never give up those dreams!
I have a suggestion (whoda thunk that?)...
Keep us informed on what you do with the boat as you make it yours, and post about your travels. We have all learned so much from you and are glad to have you back in the fold. :D
Travel safe, have fun. We couldn't be happier for you.
Welcome back, Bob! I wondered how long it would take to get you back in a C-Dory. Not long! :D
Congratulations on the new boat. Hope I get to meet you on the water someday.
Congratulations on the CD22 Bob! Sounds like a great boat for your current use. I told Cindi that I thought you were thinking about another C-Dory after our cruise with you at the Gulf Coast gathering. Next time we are over that way we would like to cruise up and check it out (if we can get in there, the water has been getting pretty skinny here at low tide this week). Have a safe trip back.
Congrats on the new boat!
Bob we really like our Origo alcohol stove, low tech and works great. Enjoy the new boat
Eric
If you need a place to stay on your way home...I have room for you and your rig.
Thanks for your hospitality a year and a half ago when I picked up my 22 C-Dory in Pensacola. Hopefully we will pass paths again.
Mike Moser
Milwaukee, WI.
Hey, I never "emotionally" left the fold....ok--maybe I did consider a couple of other boats....but nothing like a C Dory.
Yes, I am looking for suggestions. Eric, I did discuss the Origo with Marie. We had one which was a combo electric--and she did not like it. However she does have a prejudice based on the old pressure alcohol stoves. I probably need to re-explore that. I had wanted to explore the world of induction cooking--but this may not be practical. I thought I remembered a discussion of induction cooking on the C brat site.
We are also going to do the cut out of the port forward bulkhead (no barber chair, and we probably will not do a conversion.) I still have a lot of "parts" despite having given Charlie a truck load--such as a VSR--which we will use for the batteries. I have cockpit lights from the 25. There are other basics we have had in the past, we will want to include. This includes the shade under the forward hatch. We are also going to be exploring insulation of the forward bunk sides and ceiling. Closed cell foam covered with some vinyl. Some of this work will have to be done by others.
When we were in Townsend TN on our last trip--I purchased a Hammered Dulcimer--but unfortunately got a large Chromatic--I have to build or buy a "traveler" which will fit in the C 'Dory 22!....
Thanks for all of the comments and good wishes. Mike, we are planing a trip to the Wi area--and will take you up on that!
This will be an ongoing thread as our first "Thataway" thread was....
I would love to hear all of the details as you work on your boat. We have had our first boat (2006 22 Cruiser) for 3 months or so and there are tons of projects to do this winter.
For future reference, my questions will include:
* What kind of rope/chain/anchor combo will you use?
* Are you going to reinforce the bow cleat from below, i.e. with a back plate? If so, what will you use?
* Etc. :)
Congratulations! PS - What color is it?
Dr Bob,
Congrats on the "new to you" C-Dory. Great to have you official again. By the way, love that new name. What a pair to draw to.
Glad you are getting another one. I wish I had your boating expierience.Best wishes.
Dr. Bob,
As mentioned, glad you're back in the 'fold - even though you never really left.
As you may recall, when I sold "Naknek," (in my mind) I did it for all sorts of well-thought-out adult reasons having to do with fuel costs, general economy, and related issues. The one item I failed to factor in to the equation was the "emotional" aspect of owning a boat, and a C-Dory in particular.
It took me exactly a year to discover "What the hell have I done? I sold my boat! Bad decision!" ...so I began shopping.
"Katmai" was purchased four months later, and although she didn't have the equipment list that Naknek possessed, I'm slowly working to make her Mine. She's not a C-Dory, but I think we can all agree a Cape Cruiser is a kissing cousin, and still in the Family.
Katmai currently rests beneath her cover, under the RV roof here in Arizona. I can sometimes almost hear her making cruising plans for the Future - when life permits.
I probably should have named her "Magic Carpet." She's keeping me grounded with the promise of tomorrow. Boats have a tendency to do that.
Glad you're back, and look forward to seeing you on Powell again sometime.
Casey
Look forward to seeing what you do with the boat! Still refer to the Thataway thread. And yes, Bob did give me a truck (actually SUV) full of stuff with the TC! Fortunately, I was able to "re-gift" some of them to him on this trip! Hope Marie forgives me, I told Bob to blame me! It's stuff that they will need and I would not have used much (if at all). Not much need around here for PNW Crab Pots with 300' of poly line, for example.
He's on the road now between NC and FLA, hope he has a great, safe trip!
Fantastic to hear Bob, it won't take you long and you'll have Thisaway as nice as you had Thataway. Lucky boat, best wishes for lots of great crusiing. Hope to meet up with you down the road, George
Dr. Bob.
It was heart warming to see that you acquired another C-Dory. As you know I have an older (1998) 22 foot C-Dory with a single 90 HP (carb) Honda. I have had it over ten years and I have had many enjoyable weeklong trips with Kathy and myself on West Coast cruises, both North and South. We have acquired about 450 hours on our Honda. We enjoyed the time you came on our Bay/Delta trip. Over the years I have been tempted to upgrade to something "bigger and better" but I have luckily resisted the urge and have tried to keep it simple and enjoyable, with minimal maintenance, cost, and trailering issues. Like the Steve Jobs Apple computer simplicity and beauty, I find the 22 footer nearly the perfect practical cruising vessel regardless of what you can afford. It is seaworthy beyond belief and very cool to look at. For ten years I have continued to fight the urge to even put radar on my boat because I have not wanted to wreck the beautiful lines of the boat. I know I am a little extreme on my need for Zen simplicity, but it gives you an idea of how much I appreciate form and function. Your thread message has given me the additional strength to continue on with my humble and beloved C-Dory. I know you have had a lot of different boats and the fact that you came back to the bacic C-Dory says alot to everyone on this site.
Best to you.
Jim and Kath
Bob. congratulations, i am sure you will have alot of fun fixing her up. Tug
Congratulations Bob. I sincerely hope to meet you in person when you are next in the PNW.
Bob, I'm glad to see you're a confirmed boater and you just proved it. And glad to see that you bought another C-Dory, one that you can tow.
I installed an Origo stove (non-pressurized) years ago, and it took about 1/2 hr to boil water in the morning. That's why Judy and I prefer the butane stove. but if you find a safer stove that heats water quickly, let us know.
Congratulations on your new boat.
A great disturbance in the Force has been quelled. Once again all is right with the C-Dory world.
Thanks are as much in order as congratulations, Dr. Bob! :thup :thup :thup
