This past weekend I tried starting our Suzuki 9.9hp kicker (carbureted, 4-stroke) after 6 months of inactivity and I couldn't get the darn thing to turn over. I believe it was serviced immediately before we stored it on the trailer for the winter so the plugs should be good. I tried playing with the choke, in and out, halfway, not at all, and played with the throttle position. In the past when I did that, I would eventually get it to start to turn over and then start. This time, after two separate tries, I couldn't get it going. In comparison, our fuel-injected Suzuki 90hp started right up after the same amount of inactivity using the same fuel with Stabil.
It seems as if it's not getting any fuel. I'll double-check if it was serviced back in September and will either change the plugs or clean them out but besides that, any ideas?
Peter
Peter
