Well-known member
- Joined
- Nov 2, 2003
- Messages
- 21,821
- Reaction score
- 158
- C Dory Year
- 2007
- C Dory Model
- 25 Cruiser
- Hull Identification Number
- DOR25652A707
- Vessel Name
- thataway
Certainly two and three axel trailers do scuff tires--and you would have to look at the trailer as it is turning to see which tire is dragging the most. On the other hand, not much you can do about it, and I would just replace the tire.
Tongue weight should be about 7% of the total weight for a boat--5 to 10% are the range given. As long as the trailer is tracking well, and the rear of the truck is not overloaded, then the higher weights often give a better ride. (But it is very easy to overload the truck--with "stuff". Probably the best course is to weigh the entire rig, the trailer hitched to the truck, the trailer only and truck only on a scale. This will give you all of the information you need to know.
If you can move the boat/winch post, and not have it excessively overhang the bunks/rollers, that is certainly easier. I like for the trailer bunks to come to the edge of the transom Some trailer axels are easy to move, some are not. If the axels are just "U" bolted on, then they will be easy to move, but you need to be precise in the amount of movement on each side.
