Bryant":1jtj9ip3 said:
For all you Tom Cat people. I have a C Dory 22. We are thinking about a Tom Cat. What do you think of the idea of a single 200 hp motor mounted in the center of the transom motor mount?
This is not a good idea for a number of reasons. First for the 255 this is just not enough power. 200 hp is OK for a TC 24, but the 255 is considerably heavier. Several were powered with 115's and they are marginal in power.
The next issue is running a single engine on a cat. The motors do much better behind a hull or some form or appendage. I have one of the few successful single engine cats at 18 feet--and it has 140 hp, with hull weight of 1800 #, add in motor etc you are about 2600 lbs. The Tom Cat 255 is going to run about 8500 lbs, and a lot more wetted surface area.
The problem with a single engine cat is cavitation--in my 18 footer (and some of the other single engine cats, there is a pod which is molded into the bridge deck and is just in front of the outboard. This helps to some degree.
Although you might think that the engine would work better without a hull to interfere--that turns out not to be the case in a cat. The hulls both throw a wake, so that the water in the center is quite disturbed as you get up to faster speeds. This makes planing with a single very difficult--even with the HP.
If you wanted to only run the boat in displacement mode, I suspect you could with a single center motor, but there 90 HP would be plenty to get up to 8 knots. The Tom Cat is a planing cat--not a semi displacement cat--like a Glacier bay.
In other words, there is a reason that most cats have twin outboards, behind the hulls. Sorry. Buy the cat, and use the proper engines, you will love it.
