So i had a very similar issue with my tomcat that i took care of myself. One of my engines kept pointing inwards. The culprit ended up being the piston. The fix involved me removing the entire ram assembly and sending it to a seastar dealer as they wouldn't' send me a piston rod because of "liability." It's been running fine since. I also replaced the really expensive seastar fluid with aviation hydraulic fluid that meats the same specs as the sea star fluid. The advantage not only being that it's cheaper but that it is dyed red. This makes identifying leaks very easy. The fact that you have to keep adding oil indicates a leak. I also had this problem. It was due to the seals on the rams.
