- Joined
- Nov 3, 2003
- Messages
- 7,313
- Reaction score
- 2
- C Dory Year
- 2005
- C Dory Model
- 22 Cruiser
- Hull Identification Number
- CDO22289L405
- Vessel Name
- Captain's Choice II
thataway":18ul8yt0 said:Charlie description, but I am confused by "Then I turn on hot and cold water and run the water tank totally dry (mine is on the port side BTW)"
On Thataway, the water tank, and the hot water heater were both on the Starboard side as I recollect. The water heater under the helm seat, and the water tank below the floor boards of the hull. I sent along a second tank, which could be put on the port side, but was never installed.
Sorry I didn't see this earlier, I was busy getting a year older on Monday!! :roll: Bob, I'm pretty sure I saw the tank on the port side, have looked into the drain pump/box for the shower and water heater drain under the galley and thought I looked forward and saw an empty hull on the Stbd side. I'll check again. Makes no never mind, it is where it is, I'm not gonna move it... :crook I've still got that other tank, considering other uses, such as the first wine tank on a TomCat...
