john8lyons
- Joined
- Feb 17, 2022
- Messages
- 20
- Reaction score
- 4
- C Dory Year
- 2008
- C Dory Model
- 255 Tomcat
- Vessel Name
- Learning Curve
HI All,
I have at 2008 Tomcat with two independent 75 gallon tanks port and starboard. The original fuel tank vents are high on the side of the gunnel, so high in fact that there is no room for the typical upward sweep that would keep water from running right down into the tanks. https://drive.google.com/file/d/1K-CHUc ... sp=sharing
This poor design has been noted by others (e.g. Sunbeam's excellent http://www.c-brats.com/viewtopic.php?t=19284&postdays=0&postorder=asc&start=30) and it seems like the two best options to fix this are either: 1) try to fit an Attwood P-trap type vent into the original vent location https://drive.google.com/file/d/1OlxVWQ ... sp=sharing
or 2) abandon the old vent and switch to a combined fill / vent or what is referred to as a 'pressurized system deck fill'
https://drive.google.com/file/d/1NJyMLV ... sp=sharing
I like the idea of removing the vent from the side of the boat since it seems like it may allow rain or seawater to flow into the fuel tanks under certain conditions. However, I do worry a bit about the combined fill / vent caps given the location of the fill on the Tomcat's gunnel. Mine is located right by the step up onto the gunnel and might get walked on occasionally as me or others are moving around the side of the boat.
I'm also thinking about adding a Racor LG100 https://www.parker.com/content/dam/...-_LifeGuard_Fuel-Air-Separators_-_RSL0184.pdf to prevent the seemingly inevitable fuel spillage out the vents when filling up, and during thermal expansion that seems to plague me here in Alaska after filling up for winter storage. What's unclear is whether the LG100 would work with a fuel fill cap vent. My guess is that it would but I wrote to Parker/Racor just to be sure.
Any thoughts on the best way forward or experience with any combination of these products? Things are slowly starting to warm up, or at least the daylight is coming back, and it has got my itching to work on the boat to be ready for spring!
-John
-John
