squidslayer
The tank on my Tomcat used a 1/4 valve/fitting
the feed tube sceen was completly clean
you can eliminate any future issues by just replacing the valve with a 1/4 barb fitting as long as all your fuel lines and engine are Above the fuel tank
the valve is not needed or requierd then.
Tip
If you have two engines or two fuel tanks you can have some spare fuel line rigged with fittings so you can run both engines or engine off the good tank till you fix the other.I used the extra inlet/outlet on my fuel/water seperators to make the switch
switching the tank fittings at sea would not be fun
thanks again
DickE
Tip
thanks again
DickE
