Mike...":36lqvgxj said:Captain Matt, remind me. You did a shoot-thru yes? How is that working out for you?
mike
Captains Cat":4wt3eml7 said:Why do you need temperature? If it's for fishing, the fish aren't where you're taking the temperature :roll: If you just want to know, buy a little cup with a string on it and get a small thermometer. Lots better than a 3" hole in the hull....
Mike...":5jq7cbq1 said:I really only wanted to know the temp before the kids hop into the water. But as you noted, there are other options. Maybe not a cup on a string, though.![]()
mike
Well heck - that might just be enough to get a feel for the water temp. As you said, it would be interesting to compare the transducer temp to the water temp. I wonder if there would be some fairly consistent offset. Even if it wasn't completely consistent, plus or minus a few degrees would be fine.Matt Gurnsey":3jcxm5s4 said:There is a temp sensor in the in hull transducer, but I don't know how the temp reading will corrolate with the actual water temp. It is in liquid, in the bilge, with the hull in contact with the water. It would be interesting to compare the in hull TDX temp with actual water temp and see how far off it really is.
"Come here little one."Captains Cat":koqvrw3k said:Instead of a cup on a string, how about a "kid on a rope"? Dunk 'em, if the shriek is too loud :cry , pull them back in with the rope! :thup
Mike...":7bdvzajl said:"Come here little one."Captains Cat":7bdvzajl said:Instead of a cup on a string, how about a "kid on a rope"? Dunk 'em, if the shriek is too loud :cry , pull them back in with the rope! :thup
"Okay daddy."
"Daddy, what are you doing?"
"I'm just tying this here rope around your waist, little one."
"Why daddy?"
"Because I'm going to toss you over the side."
"But why daddy?"
"Because I want to know the temperature of the water."
"But daddy, won't the water be really cold?"
"Well little one, we won't know till you hit the water. If it's cold, you just holler, and I'll pull you right out."
"Daddy, your C-Brat friends put you up to this, didn't they."
:shock:
mike
