Captain Starbucks
- Joined
- Oct 19, 2011
- Messages
- 117
- Reaction score
- 7
- C Dory Year
- 2009
- C Dory Model
- 255 Tomcat
- Vessel Name
- DOUBLE BARREL
Hi all,
I've moved my 1,000 watt transducer 3 times trying to pick up the bottom on plane but I can't find the right spot. The 3 in 1 transducer isn't doing any better. It's basically the same spot on the other sponson.
Currently, the big transducer is 5 degrees down relative to the hull and about .5" below the hull running surface.
Just wanted to check with anyone to see if someone has found the perfect spot before I drill 5 more holes in my boat. I think the only logical place left is on the outside of the sponson. My thoughts are that the water is pretty turbulent in the middle of the sponsons so maybe the outside edge would be less bubbly.
