matt_unique
I was looking over the inside of my transom today and noticed a leak. Here's a picture of the leak with the tell-tale mold following the apparent path of the water. If you are looking at yours, this area is just to the left of the hydraulic steering alignment valve. There is a hole you can see right at the top of the mold 'waterfall'. When I stick in a screwdriver I'm hitting metal. Using my screwdriver as a measuring stick, it appears to be dead center with my rub rail.
My starboard rub rail on the transom bows out just a little. It may be coincidence but I suspect this slight bow is allowing rain water to pool behind the rub rail and find it's way in through the penetration.
I know our transoms are cored, does anyone know if the transom is cored right where the rub rail goes in? How do you remove rub rail? I assume you need to remove the rubber insert somehow then remove the screws holding the rub rail frame. I've never done it before though so any advice is appreciated. Assuming the transom is cored where the rub rail attaches I would need to remove it, properly seal it, and reattach it of course.
On the portside of the transom I noticed a rust waterfall from the portside transom eye. I do not see any evidence of leaking on the inside of the transom. It may be a good idea to remove these eye's and properly seal them in the core as well.
My winter project list was almost complete for this year...better to find it and fix it sooner rather than later.
Thanks for the suggestions.
