You can setup the tongue weight. There are many ways to determine what it is, including a hitch which has a scale built in. I usually did it with bathroom scales, and confirmed when I weighcd the boat on a commercial CAT scale. The rear axle of the tow vehicle with and with out trailer attatched. The boat can be moved back and forth, in some trailers the tongue can be moved, and axles moved. I also used a weight distribution hitch on my 2002 C Dory 25 and 3/4 ton Ford Excursion 7.3 L diesel.
Depending on gear the 22 can weigh from about 3800 lbs to 5,000 lbs. The C Dory 25 from 6500 to 9000 lbs. I recommend 10% of trailer weight on the tongue--but that may vary for some trailers.
I recommend trandem axles on both the 22 and 25. I broke the tongue pole on a single axle 22 trailer. Also have remote (vehicle cab) monitoring of tire pressure and temperature. Also do a walk around, with a hand held IR therometer when towing longer distances, every 2 hours. Be sure that your tires are less than 6 years old. No cracking in tread or side walls of tires.
Be sure and pack wheel bearings at least once a season. Check the grease or oil level before any trip--even if hey were "OK" the day before.
Electric over hydraulic brakes are by far the best. They are required in most of Canada if the combiled weight is over 6200 Lbs. There is some information in the literature that suggests all trailer brakes need to be on all axles, and remotely controlled breaks on smaller trailes were not allowed.
I have never been checked, but just looking at the tongue allows an inspector to surmise what type of brakes are present.
