Well-known member
- Joined
- Oct 27, 2012
- Messages
- 3,714
- Reaction score
- 59
- C Dory Year
- 2008
- C Dory Model
- 22 Cruiser
- Vessel Name
- SoBELLE
In a recent post there was some discussion of tongue weight. With a tandem trailer I would think that the goal would be to keep the axle weight pretty much the same for the front and rear axle. As a result, the tongue weight should be pretty low compared to a single axle trailer where the tongue weight is about 10% of the total.
If you set up a tandem axle trailer where the tongue is carrying ~10% of the weight (the conventional wisdom), then the front axle will be move heavily loaded than the rear axle.
From a trailer perspective I think you would want a zero tongue weight to balance the trailer axle loading.
From a towing vehicle perspective, a zero tongue weight it probably ok (IMO) However, you would not want a negative tongue weight as this would reduce the traction of the tow vehicle.
Having a positive tongue weight results in a more forward CG of the entire tow assembly. The more forward the CG, the more stable the tow assembly will be when driving down the road.
