Dan McNally
- Joined
- Jul 4, 2006
- Messages
- 162
- Reaction score
- 0
- C Dory Year
- 2005
- C Dory Model
- 22 Cruiser
- Hull Identification Number
- cd0222641405
- Vessel Name
- Shannon- Colleen
Ok Brats, help is needed again, can someone on this site offer some help with a tow problem? The long and short of it is, I have a 1995 f250 supercab 4x4 with a 460 as my tow vehicle, the truck has 90,000 miles on it and should be able to handle my 22' dory and a 9 1/2' camper at the same time. The problem is that since I had a new torque converter installed at a tranny shop the truck will hardly pull a grade, I took it back to the shop when I found the problem (shortly out of warranty) and they said every thing works fine. It does to a point, it does not slip, miss or otherwise act up, but it will only go up hill at about 20 miles an hour when loaded. If unloaded and I pull a mountain pass it travels well, but if I drop it into passing gear it shifts and the rpms increase but no increase in speed. Anyone have a suggestion as to the problem, I am not mechanically inclined but would like to be more informed when talking to a repair shop this time.
Thanks, Dan.
Thanks, Dan.
