Bob/thataway,
How is there more torque load on the transom when the motor is tilted up? From my view/analysis there's less.
When the motor is not tilted, I assume that its CG is in back of the transom, which could be wrong, but visually looks to be correct. The resultant torque is then the horizontal offset between the CG and the aft face of the transom time the weight of the motor.
As the motor is tilted up the engine block is moved forward, and this CG offset decreases. Of course the lower end/propeller moves aft, but the engine mass is dominated by the engine.
When the boat is sitting still this torque is a constant but when the boat bounces as the trailer bounces, the resultant acceleration on the motor imparts an inertial torque on the transom. The smaller the GG off-set between the transom, the smaller is the torque, since the motor mass remains constant.
As for the lock, Honda customer service said that the mechanical lock is there to relieve the hydraulic system, for storage or towing. I don't know about other motors. Also, the idea of a strut between the motor and the trailer is a good thing, but that's not possible with a 25 and an EZ Loader. If you know of one that works on a 25, please let me know.
Ron Fisher, you're correct in that the motor needs to be up to clear dips in the road, and we have one between the parking slab and our driveway, BUT the motor will kick-up when it hits. Your significant other will then discuss the incident with you, but if you were going slowly enough there is no need to replace the lower unit. I'm thinking of one of those red flags they use on aircraft to ensure that everything is in the right position. If I see it when I start the truck, I've forgotten something. Same for the plug in the transom. I've survived both bouts of stupidity.
