Trailer Boat Centering System
damason
I had a problem retrieving my C-Dory 25 at the ramp on my Float-On trailer. When an inexperienced helper was with me I could never seem to explain for them to move the boat to the middle of the trailer when coming out of the water. One time my boat came down on the carpeted fender board and broke it. I had to repair the wood and reattach the carpet. I have heard of other C-Brats having similar experiences.
After much thought and study I finally invented a successful C-Dory centering system for my Float-On trailer. This is not a complete set of plans for building, but only an idea of what works for me. I have included pictures and a parts list. I bought the aluminum from the Metals Supermarket (you might try McMaster-Carr in Atlanta, GA also). I bought the stainless bolts from a local hardware. I bought the thermo-plasticized trailer rollers from West Marine.
All Parts
Main Parts
When retrieving my C-Dory I set the rollers (port and starboard) to the IN position (the inward bolt stop) before backing down the boat ramp. The boat is floating and the Float-On trailer is lower in the water below the boat. I winch the boat forward to the bow chock and install the safety chain. When I drive up the ramp the trailer moves up to pick up the boat. Only vertical movement of the trailer is done. The rollers simply guide the boat to the center of the trailer.
IN Retrieve
After the boat is out of the water I set the rollers to the OUT position (the outward bolt stop) by pulling on the eye bolt to change the setting. While towing the reason I set the rollers OUT so the rollers do not rub on the boat.
OUT Travel
I installed this system at the very back end of the trailer just forward of the rear stop lights and license plate.
Aft View
I chose the five inch thermo-plasticized trailer rollers because they do not leave black marks on the boat. The total cost for this project came to just under $250.00. With some minor tuning it allows the trailer to almost center the boat and the boat never touches the fender boards. I can now retrieve my C-Dory single handed if necessary.
Trailer Roller Parts List
1 piece 1" x 3" x 8.5' - 1/4" thick channel aluminum
2 pieces 1" x 4" x 22" - 1/4" thick channel aluminum
2 pieces 1" x 3" x 10" - 1/4" thick channel aluminum
2 pieces 1" x 2" x 10" - 1/8" thick channel aluminum
2 pieces 1" x 3" round aluminum tube with 1/2" center hole
2 each 5" thermo-plasticized trailer rollers
2 each 3" x 3-1/2" misc. plastic sheet for shims
Stainless Hardware
2 pieces 1/2" x 5" bolts with Nylock nuts
4 pieces 7/8" x 5" bolts with Nylock nuts
4 pieces 7/8" x 4" bolts with Nylock nuts
4 pieces 3/8" x 1-1/2" bolts with Nylock nuts
4 pieces 3/8" x 1" bolts with Nylock nuts
2 pieces 1/4" x 1" eye bolts with 2 nuts each
Misc
2 bungee cords (to hold the device in position)
Shop tools needed
Drill Press
Bits and End Mills
Band Saw
Sander
Wrenches
Hope this helps you if you have a retrieving problem. :lol:
Package it up as a kit, I'll buy it and have Gary Estes install it. Seriously - centering on retrieval is our biggest nightmare, that boat just WILL not center itself, I have wondered if it is somehow the rollers being out of adjustment or something, or just the flat bottom. This is a problem we need to solve, and it looks like you have devised the perfect solution...Our trailer is a King Saltwater but the brand of the trailer should not matter, correct?
Excellent idea and well executed.
I have the same problem with the RF 246 so it's not just Pat's flat bottom :-)
Probably would have to adjust the dimensions some to fit my rig but that's no big deal.
Thanks for the post and the details.
M
You guys just need to bite the bullet and get a TC255. With that hull and trailer setup, you don't even need the side guides if you can find the end of the trailer and get the tunnel over the inner bunks.
Probably a more expensive fix though.. :roll:
When I first got the Mary Ellen I noticed the problem of getting the boat to center on the trailer. I came up with a easy fix that works for me. If you look at our album on the first page you will some pics. I simply slip the carpeted guides over the trailer side guides and load the boat. I can see in the mirrors how much clearance is on each side. If it is not centered correctly I just back down into the water again until the boat is floating and then head quickly up the ramp and it is centered. I then take the guides off so they do not rub as the boat is towed down the road. It is easy to build.
Slick- Could you change the boats to a pin system so that wrenched aren't needed for the changeover? Something similar to the pins used on your truck hitch?
The flat bottom of the C-Dory, with no strakes for rollers or bunks to use to center the boat is the culprit. Sometimes not putting the trailer as deep in the water may help as well. And it should work on any trailer.
Big Mac,
what keeps your spacers from floating away as you back the trailer in, or if the boat bumps while loading? Did you just make sure you had a snug fit, and that is all that is needed?
Yes, they are a snug fit and I have never had any trouble with them moving while loading. This method has worked for me for about 9 years. They are easy and cheap to build.
Matt,
I could be wrong, but I think the way it is designed, the angle pieces have a notch in them so they are retained by butting up against the bolts (as opposed to through bolted).
we use a bunk trailer with goal posts and flat 2by6 to guide boat right in look at photos on page 13 I still have problems getting pictures to show up .
Jim- Are these the photos?
Alum . trl. with 2by6 plastic tops and 3by 8 beams covered in rug. Great trailer- the cc-23. loads so nice!
Continental 2450 alum. trailer with 2by6 bunks with plastic tie down tops. They come in 30 in lengths.
Joe. :teeth :thup
Yes Joe thanks I tried to pull those up to no avail ?
The way the trailer is set up the cc-23 (venture) slides on and off so easy I think the cc-23 has a deeper v in the front making it easier to guide between the 2by6 slots . I'm not sure if this set up would work on c-25? I still do not like to trailer the cc-23 .
Thats one of the reasons I bought the 16 cruiser to take up to tennessee in the summers. The sweet 16 c-dory is its so easy to trailer
