Pat Anderson":3pjsfx4t said:
Huh? You certainly can power the boat up rollers - David does it every single time with his CD25, and we have done it enough times to know it works fine too...Patty is uneasy about powering on the trailer at all, but not related to rollers versus bunks...
It's not something I'd be comfortable doing, but I'll accept it's possible at a good ramp. Still...I'll maintain that if good ramps are the norm, bunks are the way to go.
This is, of course, another single/twins type debate, and everyone has their own valid opinions on which works best. My reasoning:
When I power on the bunks, I know the boat is going to stick, regardless of the steepness of the ramp. This allows me to do my "tennis shoes only" retrieval...walk up to the bow, climb over the rail, step on the trailer, latch up the boat and winch it up tight. I can then step from the trailer to my dropped tailgate, and either step to dry land, or have Dana pull us out with me in the bed of the truck. Neither of us gets a foot wet, even when no dock is present. There's no way I would climb over the bow and on to the trailer if I had a roller...too much risk it would skate back on me, particularly on a steep ramp.
And...with stong side-guides and properly placed bunks, the boat pretty much centers itself when powering on, even if I screw up the approach. I've hit the trailer 20-30 degrees from straight, and it still centers right up. No way that would happen with a roller.
In the "bad ramp" circumstances I was describing where the roller has a real advantage, the issue of power loading doesn't really apply...it's just not possible. At two launches in particular, we routinely crank Pee Wee up in water shallow enough to prevent lowering the engine.
