Trailer Question
Valkyrie
Hi Everyone:
The new 22 Cruiser is ordered, options pretty much decided, but I have a question on trailers. I've been through the forum on the topic and read all of the single vs dual axle arguments and now I'm looking for personal experiences of those with single axle trailers.
The dealer is recommneding a single axle Load Rite bunk trailer rated for 3600 pounds. Have any of you with this, or a similar trailer, had any problems with this set-up? Not just in theory, but in actual practice?
By the way, I will be using it to travel long distances.
Nick
"Valkyrie"
I would strongly recommend the tandem axle trailer w/disc brakes. My current trailer that I just bought for my new 22 CD is a tandem axle, King, disc brakes, 4500# capaacity.
I've made several trips on the AK highway between Fairbanks & Washington with both the single & tandem axle boat trailers and the tandem is far and away the better way to go. Particularly if your running the longer hauls. I have a 365 mile trip from my home to the closest salt water as well.
The tandem rides much better, smoothing out a lot of rough spots and the safety factor is significant. Year before last I went down to Valdez. dark and rainy weather. I stopped and checked the trailer and tires several times during the trip but not during the last 60 miles of the run. When I got to Valdez my right rear tire was gone. Just about 2 or 3 inches of rubber extending around the rim. With the tandem I rolled right on in without incident. With a single axle, the only thing I can say is it would have been an entirely different story. Plus, the tandem gives you brakes on 4 wheels instead of 2.
Just my humble opinion.
I had a similar experience with a blowout. The right rear let go. The only way I knew was I saw something like mud flying up in the air behind the boat in the side miror. Since I was running on a brand new paved highway I new it could only be my tire. I slowed to about 45 and the safest pull off was a few miles ahead. I was suprised to find most of the rubber but the best part was the rim never touched the ground. I've seen singles wheels let go and if you don't get stopped quick chew the rim beyond repair. Not sure what your tow vehicle is but a tandem will track better and cradle a boat much better than a single axle. The boat is basically balanced over the axle front to rear. With two axles there is not quite the balancing act. Just like when you carry something large in two hands instead of one hand. With a C-Dory it is easy to throw tons of stuff in the cockpit setting off for a long trip. With a tandem this effect isn't that dramatic. With a single axle all that weight is to the rear of the one axle. If you tow vehicle was a one ton truck you might not notice but this can cuase rearend sway in lighter vehicles. Not sure what the price difference is between the two types but it is money well spent. And more brakes are more better. One more thing. The tandem fender is usually a much better step up for climbing in over the side. You will perform this feat thousands of times. Strangers will too as they want to see your new boat.
Good Luck,
Chris
I've been promoting tandem axle trailers for all these reasons and more for several years. In my opinion, the major reason single axle trailers are sold with CD-22's is to provide a cheap way for dealers to finish off the deal without driving the total price up and placing the final figure into the rejection range. Anyone who seriously thinks it out goes for the tandem set-up, unless they live within a few miles of their most common launch ramp and don't intend to travel any real distance. Joe.
Have to agree with all the tandem touting. I pulled my CD 22 on a single axle trailer for a few thousand miles total, and never had a lick of trouble. But I was worried about it every mile of the way. One old guy even accused me of being "trailerphobic".
When we got a trailer for the CD 25, I followed Les' advice and went with the next higher rated trailer than needed. It was about $500 more, but the peace of mind is well worth it.
What those guys said about tandems :thup
I have been towing on a tandem since 1991, making long runs from so Cal to Washington and British Columbia.
I like my tandem Pacific Trailer.
But then on the other hand....a single axle trailer that is rated to safely haul your boat, will safely haul your boat, if properly maintained. There are benifits to a single axle, they're more manueverable as you don't have those tires fighting each other when you turn, they have less rolling resistance so you'd would get better milage and they have less parts to repair and replace....That being said, I wish I had a tandem axle trailer for all the above posted reasons
My next trailer will be a tandem and i will step up to the next higher rating regardless what the sales people think.
And that is all I have to say about that, other than it is VERY difficult to enjoy the boat you LOVE without a reliable trailer. DON'T SKIMP. Oh, and get a spare carrier or two.... and carry replacement bearings, grease, jack and parts to deal with any trailer related issue you may encounter on the road... and that's all.....
And DO NOT GET A SURE LUBE SYSTEM! Bearing buddies would be much better...
And go with stainless disk brakes....
And that is all
And a beefy tounge jack...
that's it, gonna find a quiet place and make some noise.... I got trailer issues... Umm hmmm again.... yep.... single axel, 3600 lb rated POS.
But if you want a great deal on a single axel trailer I'll let you know which bridge I push mine off of when I replace it....
And that's all I have to say about that....
I would suggest geting a trailer with at GVW of 5,000 or 6,000 lbs for a 22 cruiser.
I have weighed my boat and trailer and I am right at 5,000 lbs. We use out boat for long distance cruising and the supplies and gear mount up. The factory weight is for an empty boat.
I think its better for the trailer have some reserve capacity. The tires, brakes and springs will last longer.
If I buy a new trailer it will be a galvanized 6,000 lb GVW tandem, with disc brakes on all four wheels.
Tandem trailer with disc brakes on all 4 wheels :thup
A trailer rated at 6,000 lbs GVW, means that after you subtract the trailer weight of 1,200 lbs, you can carry a load of 4,800 lbs. (load includes full gas tanks, full water tank, downriggers, ice chest, remaining fishin gear & mother-in-law)
GET THE BEST TRAILER rated TIRES THAT YOU CAN AFFORD!
Bill's 2 cents
This is clearly a belt AND suspenders crowd. I have the LoadRite single axle trailer that Cutter Marine sold with the boat and haven't had any major problems. However...
1. My launch and retrieve distance is about 60 feet for most outings (I keep the Otter on its trailer at the marina).
2. On the one really long trip we took (about 1400 miles), I did have one blowout and, yes, I had to stop very quickly in order not to damage the rim.
3. I've had more maintenance costs with trailer brakes, bearings, and tail lights than with the boat (okay, maybe thats a slight exaggeration, but I don't mind paying for maintenance on the boat nearly as much as I mind paying it for the trailer).
If you plan a lot of miles, I think a tandem would be a good investment, especially if the difference is in the $500 range as someone said above. One other tip: after replacing the so-called submersible tail lights a few times, I gave up and fashioned a light bar that I attach to the back of the boat when I travel. It takes a few minutes to put on and secure the wires along the side of the trailer each time, but it never fails and it never gets wet!
(Isn't it funny the things that one ends up having opinions about? A few years ago, I'd never have thought that I'd be holding forth on the virtues of a trailer light bar!)
After what happened today, without a doubt get a tandem trailer. I was towing on I-5 during rush hour just north of Tacoma. You guys know the area, it's like towing over 2 x 4's every 10 feet. Somewhere in that area I had a major blowout on the back left. Didn't know about it until someone starting honking there horn and pointing. Well, I pulled over after traveling another 10 miles ( couldn't any sooner, damn semi's had me sandwiched in). I couldn't believe what I saw, the back side of the tire was gone, yes gone!!! The only thing that saved my bacon was the second tire. I was able to drive to the next exit and have it replaced. No telling what might of happened on a single axel.
