Gulfcoast John
Well-known member
- Joined
- Dec 14, 2012
- Messages
- 1,190
- Reaction score
- 55
- C Dory Year
- 2010
- C Dory Model
- 255 Tomcat
- Vessel Name
- CAT 'O MINE
We've had 3 trailer tire blowouts (more like explosions with shredded steel belts) with our prior big Regal 2665 cruiser rig (also 10K#), the most excruciating on the 8-lane section of I-10 through Mobile. It made us want to do anything we can to prevent recurrence. We already replace all trailer tires including un-used spares every 36-(absolute max) 48 months from manufacture date (stamped in code on all tires) regardless of pristine appearance (call us once-burned). We never exceed the 65 MPH max speed design limit of all ST tires (DOT Special Purpose, which includes all boat trailer tires). We bought an expensive remote RF tire pressure/temp sensor reporting system that almost paid for itself today.
http://tsttruck.com/
The reason I argue that is because big heavy trailers use tires that are engineered to bear only their rated load and never twice that, not even for 30 seconds. So, when you have the inevitable blowout and have to maneuver to the shoulder when you can do so safely, you are doomed to replace not just one, but 2 $140-$190 trailer tires (3 for triple axle trailers).
One trailer tire went from 82 PSI to 31 PSI while parked at the marina, and the alarm beep/flashing red LED on the tire monitor got my attention (even without my hearing aid). A nail in the parking lot? Who knows.
So we wrestled off the bad 100# or so tire in today's 110 heat index heat advisory. As a condition of sale, the PO agreed at survey to replace all tires and provide a spare. The spare tire had the wrong lug nut pattern and there was NO WAY to use it! OK, I'm a dope and I admit I never confirmed my spare has the right lug nut pattern. I'm SURE you have.
We had already wrestled off another trailer tire yesterday (112 heat index) when the monitor alarm went off showing 25 PSI on it and I took it to our tire guy...slow leak in a bad valve stem. It's AMAZING how a boat trailer tire with 25 PSI and one next to it with 80 PSI look EXACTLY THE SAME.
I admit that I considered this system as somewhat of a 'boy toy' and that it is expensive... but we all demand that remote sensors tell us RIGHT NOW if our truck engine temp is high or oil pressure low...what's so different about trailer tire pressure and temp, in this age of ever-cheaper remote RF sensors?
I really like seeing each trailer tire pressure/temp displayed for 30sec in sequence (any sudden change reported immediately with an alarm). This system is made for commercial 18-24 wheeler truckers, but it works for me, too.
The median C-Dory Brat tows a 22 and is not an 8 ton rig like us, and doesn't need this. In a Worst Case Scenario the average C-Brat disabled boat/trailer can be winched onto any car hauler and be under the 13.5 ft federal bridge limit hght, but not a 255.
I will bet (Me the Outlier) a box of Black Box Pinot Grigio that we are the only Brats using a remote RF system like this. I just want others to know that the technology exists, because it took me years to find it on my own.
I now know Dr Bob is also (among his many other talents) a Big Rig RV driver...He may be familiar with the pros and cons of these systems, and if so, I hope he will offer his opinions.
As always, and in advance, Your Mileage WILL differ!
HAPPY BOATING!
HAPPY BOATING!
