Noreaster
- Joined
- Apr 24, 2007
- Messages
- 86
- Reaction score
- 0
- C Dory Year
- 2006
- C Dory Model
- user_field_choice.c_dory_model_16_Angler
- Hull Identification Number
- CD016624C606
- Vessel Name
- Nor'easter
It seems like whenever I have my boat in the water for more than a couple hours I get a little water on the floor. I'm guessing it's coming thru my transom plug. I've changed it several times but still end up with a little water on the floor. Has anyone ever had issues with water going around the plug (between the brass fitting and the transom)? If so how would I fix it? Also, does anyone know if the coring is sealed before the brass fitting is installed. I'm concerned that some rot could set in if it is not sealed.
