Has anyone ever tried to use a 25" shaft (xl) outboard on a 22 cruiser by building a transom riser?
I envision an aluminum structure that fills the transom 5" high, maintaining the width of the transom, and overlaying the transom on both sides.
I'm a big fan of overkill (someday ill post the windlass backed I had made and the process I went through to drain my anchor locker) and so would want to extend the riser to the bottom on the outside.
I like the idea of my motor being a little higher. I was planning to get rid of my spring loaded kicker mount on my port corner ( a death trap!) and move it amidships next to my main an tie the steering together. The mini jacker would get the kicker out far enough to clear the trim tabs, but if I had the riser build, I could extend it to the sides and weld a kicker mount to the transom that allows my kicker to tie in steering and cleaner the tabs. I could also put my transducer on there and have no more holes below my waterline except the lower motor bolts.
I wonder if I could reuse the same lower bolt holes?
I wonder if there would be major performance or handling issues?
I wonder if anyone else has done this?
I wonder if anyone has ideas to improve, warnings I should heed, lessons earned, or experience to share.
I live in a commercial fishing town, and know for a fact that anything can be done to a boat. That much I'm sure of. Whether it should be done or not, that's another matter entirely.
