gulfcoast john
Greetings from Montreal at the Old Port end of the Lachine Canal through Montreal!
New pics from the end of the Rideau Canal at the Flight of 8 staircase locks at Ottawa on page 13 of the album (we started at Kingston, Ontario). And some on the Lachine Canal.
We have been impressed with the close-quarters boat maneuvering skills of the avg local Canadian boater compared to Florida boaters (who have a vastly longer season to use their boats). Everyone here and throughout Ontario and Quebec is very welcoming and curious about how a Florida boat got to Montreal.
Locals told us that the alternative St L Seaway canal could have delays of 8 hours at each of two locks because big commercial ships have priority. Recreational vessels pay $30, the avg ship pays $77,000 per lock. There may be something to that old saying, “Money talks….and C-Dory owners don’t have that much.” The guidebooks mention commercial traffic has priority, but not that delays could get THAT bad.
So do whatever it takes to get your air draft under 8 feet and into the Lachine Canal through Montreal...remove radar, arches, etc. (And also the dog, in the unlikely event Mick Romney is reading this post).
We had an engine overheat alarm at one lock, though only 133 degrees at idle and 138 degrees is typical at cruise. 131 on the other. However, these engines have proven over time that they know more about themselves than I do, so we told the lockmaster we had to break out of the group (they like to keep boaters locking through in groups) to troubleshoot. The poor thing didn’t have its typical studly pee stream, only weak and intermittent. We found what looked like primordial slime and algae in the intake strainers. I hooked up the transom shower connector to our pocket hose and used the freshwater pump to flush the intakes for about 10 seconds, when the pump quit. A local boater pulled up and had a wire brush to attack the strainer grates, which got out a lot of sludge and re- established a healthy Yamaha pee stream. That night we removed 5,000# of stuff from the cabinets to access the freshwater pump, which lives at the bottom of the starboard sponson. I found the 12v + butt connector had separated...this will be easy!...NOT. replaced it and all fuses, no joy. Electrically dead. My bad knee was throbbing and I didn’t get around to checking the pump on a known good small 12v battery since Eileen insisted we could get by on gallon jugs of water for flushing and cleaning dishes.
My Nav display is going dead intermittently at the worst times. We can switch Eileen’s display from engine and depth data to Nav Chart, but it is harder for me to see. Troubleshooting to date not revealing of anything. I suspect the 12v power plug, but it’s a 90 degree plug on my unit so I can’t just switch them out. Helm fuse block connections are solid.
The most frustrating issue of this adventure has been my knee injury. I know enough to know it’s not serious, just obnoxious. But our plans to walk our daily 6 miles per day at each stop are stymied and a bit distressing. On the other hand, we should be grateful we could be seen at an Urgent Care clinic and get Xrays with no deductible or co-pay, and an Ortho referral for when we return to the US (probably this week in Plattsburg on Lake Champlain).
Tomorrow we may make over 80 miles cruising, which is easy in a 255 on a calm day.
Next year we plan on being at Bellingham and 6 weeks around the Puget Sound!
Safe travels, and hope to see you there!
