Active member
- Joined
- Nov 7, 2003
- Messages
- 7,973
- Reaction score
- 13
- C Dory Year
- 1984
- C Dory Model
- 27 Cruiser
- Hull Identification Number
- wn something
- Vessel Name
- to be decided later
Well I had trouble with my honda 225 this weekend and it was a mystery figuring it out that took me down the wrong road at first and made me waste a lot of time. In the end I was able to fix it with a few tools and part I had on the boat. I did have to get one piece of wire but I could have done it with what I had to get home.
So while running to FH I kept getting a alarm followed by the engine shutting down. Looked like a over heat alarm. I would restart and idle just fine but as soon as we took off the alarm would sound and the engine die's again. No blockage of the piss water, no seed weed on the lower unit and no hot motor????? Well I could not figure it out in SJ channel with the ferry coming at me so I fired up the kicker and we crawled into port. Every time I think about getting a sail boat I should do this to remind me that going that slow is just nut's.
So I figure that I have one of two problems 1) stuck thermostat or 2) a bad sensor on one of the heads. I have a v6 225 Honda which has two sensor and two thermostats. So after a little polling and soul searching I pulled the sensor connector and tested then with a volt meter set for continuity. The sensor should close when the right temp is meet. So if sensor is good I should NOT get a beep or tone when I touch the probes to the two connector prongs on the sensor right???? Yeah right. So after finding both sensors to be good I moved on to the thermostats. Easy to pull. It's just 5 screws for the cover and three bolts for each thermostat. Get them out and boil then on the stove to see if both open. Which they did. Now cool to see if they close and they do and then repeat 5 times for good measure. Ok so now I am out of ideas and day light. Put it all back together and start it up and it runs fine??? Well that is at idle so lets tie the rope's a little tighter to the dock and but it in gear and run it to 1500 rpm to generate some heat in both forward and reverse... all good with out any shut downs. Must have been a stuck thermostat and boiling it unstuck it. Ok off to bed for some early ( well kind of early) fishing..................
Get up start up turn the wheel so I can back out and the engine die's.......WTF OVER..................
Well lets do that again. Engine on? Fine, warms up? Fine turn the wheel right ....fine turn wheel left?.......died. The repeatable action was turning the wheel left and the engine dies ever time. Not some thing I was paying attention to while the ferry was heading my way. Better part of valor in the channel is running like hell on your kicker while you can.
So after thinking for a while I started to take the covers and holders for the wiring and fuel line harness where it enters the motor because that moves away from the engine as you turn left????
Ok 200 more screws and bolts later I find that the secondary positive power cable ( there is one for the starter and one that goes to a fuse panel that powers everything else on the motor) had pulled apart inside the rubber casing. The wire was not in two parts , to be clear, but the copper strains inside the rubber casing were broken and separating when I turned left but pushed together when the engine was straight or turned right. No outward sign of the brake. You had to feel it with your fingers inside the casing. Well I cut it open and used my stores of parts and toos I keep on board to splice in ( wire crimps with heat shrink) 4 inches of new wire so there is enough wire so the movement would not pinch and pull the wire apart again. Re-installed the 200 screws and bolts that honda finds just sufficient to hold this all in place and went fishing around Noon. End the day with a 17lbs king for a visiting family member and ended a great trip. I hope this may help some one in the future that has a similar problem that they can not figure out.
