Well-known member
- Joined
- Nov 2, 2003
- Messages
- 21,834
- Reaction score
- 192
- C Dory Year
- 2007
- C Dory Model
- 25 Cruiser
- Hull Identification Number
- DOR25652A707
- Vessel Name
- thataway
I have been towing my C Dory 25 for about 18 months behind my 2012 Yukon XL 4 x4. It is at its max towing the 25. I had not even considered using it for that, until we bought my son's 25, and hauled it over the Grapevine, on I 5 on a 110* day a few years ago. It overheated the transmission, but cooled down easily and did fine the rest of the trip.
I started looking at Chevy 2500--big trucks! Expensive trucks. But the fuel tank is only 22 to 24 gallons--and that is awful small! I went to my after market dealer--no problem with a diesel you put an aux 50 gallon tank in the bed all done for $650.
Then I began to think about running costs and the price of diesel. The truck is my daily driver, so a 20' truck becomes cumbersome. Also after looking at a few sites, the "modern" emission controlled diesels, are not getting all that much better fuel mileage than the gassers--and when you factor in the differential cost of diesel fuel--it is about even, or even sways to the gas.
Today I began to look at 1/2 ton pickups--all of the majors have a number which will tow in the 9500 # range. They are lower, and a little smaller. Certainly cheaper. But they all have small fuel tanks ( I have a 31 gallon in the Yukon, and wish I had more). The problem is on long trips, finding a station which is large enough and not too busy, to get the rig and boat around to a well located pump.
We have been getting 9 mpg average with the 25 (we did 12 to 13 with the 22). Some of the newer transmissions probably would get 10 miles per gallon with a similar sized V8 Gasser. (This was also the mileage I was getting towing the first 25 behind a 30' V 10 powered RV which had a beefed up transmission/cooler and hitch). We towed our first 25 with the Ford Excursion 7.3 and got 12 to 13 mpg on the high way.
I find that many of the Ford 150's are ordered with the 36 gallon fuel tanks. This sure beats a 22 gallon tank! Right now, I am leaning toward a Ford with the 5.0L V8 and 10 speed transmission which I can get in the low 40's with the accessories I want. I have yet to look at the Dodge and Ford Diesels. There are not any 1500 Dodge with the 6.7 L Cummins around anymore. (No Tradesmen with the 6.7 in the 40's around here!). There are some good prices as the end of the 2019 models are wrapped up. I even found several bright red new 2018's--but the price was too high for a red truck! (Wanted as much as for a '19).
Comments on what others have found towing the 25 as far as mileage, and power. We have electric over hydraulic brakes on the trailer.
