We fish and cruise in the Apostle Islands, Lake Superior. We're running twin Merc 40hp EFI motors on Aeolus, a 22' cruiser. Aeolus is on the trailer when not in use.
A couple days ago, after a day of cruising with all systems normal, we made a stop for photos near an island. After the stop the port engine starter would not engage, it just made a spinning sound. I initially thought it was low voltage on the port battery. We were 18 miles out in the islands and evening was approaching, so we scrubbed plans to anchor for the night and cruised back to town on the starboard engine.
Three hours later, well after dark, we made it back to town and decided to anchor near town for the night and load up in the morning. The starboard motor ran normally back to town. The battery voltage indicated 12.8 volts with chart plotter, autopilot, VHF, and LED nav lights running.
After dropping the hook, I went to set the hook with the engine and no go with the starboard engine, only a whirring sound from the starter, just like the port side earlier! I shut down power to the electrical panel for the night (Perko switch to OFF). The next morning I was able to start the starboard engine manually with a pull cord and we cruised to the ramp an loaded up.
At home, I checked both batteries individually on a charger, both indicated 12.8 volts, and 90% charge. After charging both batteries, the problem remains the same, neither engine starter will engage, both starters spin but don't engage the flywheel. (Perko swith set to OFF)
Bad batteries? Corroded battery cables / connections?? Double starter failure?? It seems unlikely to have both systems fail on the same day!!!
Has anyone had a similar occurrence or have any insight to possible cause of this situation? I'll post my findings as I dig in and trouble shoot the problem.
Thanks!
Thanks!
