Active member
- Joined
- Nov 7, 2003
- Messages
- 7,963
- Reaction score
- 2
- C Dory Year
- 1984
- C Dory Model
- 27 Cruiser
- Hull Identification Number
- wn something
- Vessel Name
- to be decided later
Another idea that rolls around in my mind is this, how far do you plan on going if you have a systems failure? I mean really? if I lose the gps and the radar and the depth finder all at once, how far would i cruise with out them? Not far. I only need to get to a safe place to tie up or anchor so i can go thru the systems and get them back online. Its not like I would continue to cruise Alaska with out the electronics working. If I cant get it working in a few hours then its a problem that has to be sent to the factory or just replaced and lets face it there is nowhere in the U.S. these days that is not a days travel by air or car from a good sizes town and FedEx. the days of the frontier are gone.
Which leads me to another subject. Reading the water. I fell that I'm very good at reading the water. the water will tell you a lot about what lays below just by looking at it. the shade of color, the texture of the surface, the weed lines and rips. All these things will give you a idea of what the water around you hides in its depths. Now I have boated with out a single piece of electronic for years. mostly on lakes, rivers and some salt but it all applies. I think that learning to run and row rivers has helped me avoid danger in the salt more then anything else. tides and currents show you the same things that a current in a river does.
my first electronics gear was a depth sounder and I can find my way any where with just a sounder and a map. Now having a chart plotter makes it all easier and safer for the beginner but I think doing with out teaches you more in the long run and makes you a better boater.
