Well-known member
- Joined
- Nov 7, 2003
- Messages
- 7,984
- Reaction score
- 26
- C Dory Year
- 1984
- C Dory Model
- 27 Cruiser
- Hull Identification Number
- wn something
- Vessel Name
- to be decided later
If I was going to get another auto pilot it would be the Garmin/tr-1. TR-1 sold to Garmin last year. The Raymarine I have is great for what it is but it has its short fails for fishing and is behind the curve in technology. It does not track well if going to way points. You can only get within a certain distance from the way point before it decided it has arrived, within a few 100 feet or more. That’s great for sailing and cruising long distance in open waters, which is what it was meant to do, but sucks ( tech term) for fishing or close courters cruising.
I have had two way points set near a rock or point and the Raymarine would want to go to the next way point before getting all the way to the first way point. Well cutting that corner meant going over the rock or the point, not good. The Garmin on the other hand will not "arrive" at a way point until you are on top of it. It will also hold a course with in 2 degrees from a bearing line between two ways points. The Raymarine will drift a hundred feet or more from that line on either side. You end up with a back and forth crossing of your bearing line that drives me nuts. This is why most people just use the heading function which works a lot better.
Where the Raymarine has fallen behind in the tech wars is the over ride function. If you are on auto pilot and a log appears before you, you can grab the wheel and spin it hard to port, or starboard, and over ride the auto pilot for a few seconds. All fine and dandy but the auto pilot will reengage bring you back to you heading, which is what it was designed to do. But if you are in a large debris field you have to do this several times or disengage the auto pilot. With the shadow drive system of the Garmin all you have to do is grab the wheel and turn to a new course and let go. The auto pilot will reengage on the NEW COUSRE without you having to hit any buttons. It will do this all day only without you ever having to touch a on or off button. Don’t like your heading? Just grab the wheel turn 30 degrees to the north and let go , bam you’re on a new auto pilot course.
Whit the new shadow drive and the tighter course settings Garmin is a better unit for my uses. Added to that is the ability to troll BACKWARDS. This is great for bottom fish and river fishing Will I go out and replace my raymarine unit? NO but the next boat will be a Garmin.
