C Sniper
- Joined
- Mar 17, 2019
- Messages
- 61
- Reaction score
- 2
- C Dory Year
- 2007
- C Dory Model
- 255 Tomcat
I am wanting to keep the temperature down inside the cabin when locked up and not in use. Mainly as I am hoping to minimize degradation to the power station that runs my mini a/c. If I can keep the inside below 104 I could even charge but that is not critical. I am considering putting in a Marinco (formerly nicro?) day night solar fan. Has anyone put one on the roof of a 22? I am planning to try to measure roof camber today as the vent documentation shows max of 1/2" per 12" for proper installation. Could do a hatch install too but the hottest air is going to be up high.
Any input appreciated as I hate the thought of cutting a huge hole in my roof and then regretting it later.
Another idea I had was putting a high output computer fan and PVC pipe behind a back rest cushion and vent thru the hole the electric comes into the cabin. Would probably have to cut another hole on the other side for opposing flow. In this case first first hole already exists and the second hole, if later regretted, would not overly visible unless you're looking for it or accessing storage under the bench seats as it would be hidden behind the back rest cushion. (I have the rare commuter version without kitchen and dinette table). Same issue as hatch option above as not venting out from the roof, I am guessing, would have less cooling effect given hot air rises.
