Change from my 2 cents - 1 pennys worth -
IHMO:
I would caution against anyone using any 'booster' to be used by, or with, the VHF Marine transmitter. The VHF Marine radios are FCC type accepted and can't be modified in this fashion without violating the regs. The max power out is also a part of these regs. as 25Ws. If by a 'booster' is implied for the receiving signal, well that would probably be OK. However these radios are transceivers, meaning that they are not a separate radio transmitter and receiver, but combined into one unit.
As to the short coax-
Sark, if your coax is of the RG-8X version, you will probably not notice any difference if you added a short jumper with a barrel in line as long as each connection high quality and is good and firm. Even if not RG-8X, I would use the RG-8X as a jumper, verse RG-58 types. I use RG-8X for these frequencies and the loss for the short run you imply will be very small.
I would suggest you try adding a jumper; try a long haul communication with someone you have talked to before, and see if it meets your range needs and experience. If so, your only out the time and a few $$ for the jumper.
I would also suggest that if you can get a copy of the Powerboat Reports, Feb. 2007, they have an excellent article and review on 10 different VHF antennas starting on page 12, thru 16. Their comparison was, in part, covering the 8-foot, 6db-gain, antennas that ranged from abt $36 to $159. The manufactures are COMROD, DIGITAL MARINE and SHAKESPEARE.
Hope I did not add too many 'fly spects' to the questions answer.
Think I'll head out to modulate the feather rester so I can up early to go to the Atlantic Boat Show in the AM. in VA Beach.
