OK, just this second came in from the boat to inspect the Webasto install after reading the Webasto installation manual, which says "Under no circumstances draw combustion air from an area occupied by people" or something to that effect. I also looked at the illustrations, and all I can say is, it is a good thing I did not attempt this install myself! In fact, the vent in the hanging locker door is simply to allow cabin air to reach the heated air return. The combustion air intake hose actually goes (although it was practically impossible to see without major contortions) through a neatly drilled hole into the area of the gunwale just forward of the gas filler tube, so it is drawing outside air for combustion in an area well protected from water. So unless we decide we need a second hot air outlet, I think we are in good shape!
