Dutch the last time it went to the shop I had the same problem you are having and I got the “check the voltage" run around from everyone including the repair shop. Turns out that it was a bad relay board on the back of the unit. This relay tells the computer if the top is open or not. During start up the computer will ask this relay or switch if it’s ok. If its shorted out the way mine was then it gets no answer and the unit shuts down. It’s the same thing for the glow plug and the fan switch. So you have to take the unit out to get to the switch and then take the back of the unit off, its only two screws. You CAN NOT get the switch board thingy (what is this green soldiered P.O.S. board really called?) from the outside. There are two screw heads on the outside, or so I thought, but they are really small bolts and you have to get inside to get to the nuts. Anyhow take it out and see if it is corroded. Mine was really bad. If you let the crab over boil and hit the top of the stove it all runs right to this board thingy. Hope this helps.[/quote
Hi Tom
I recently checked out the P.O.S. board on my stove while trying to solve a different problem. I've been calling it the cooling fan circut board, but not sure that is correct. I think we are talking about the same part, and its possible you might have guessed its correct Finish description. Anyway it had a fair amount of old cooking oil on it. Scan/Mike said to try CRC brand electronic cleaner in spray can, commonly found in auto stores. He said to spray it on until oil is softened then air blast debre off. He said typically they either work or they don't. I know your problem wouldn't have been improved due to corrosion, but thought you might appreciate the tid bit.
