Lynn Marie
Last season I found water in the cabin a couple of times and after thinking it was leaking around the door or through some other normal space I discovered that if I had water up the starboard side there was a small trickle of water coming in around the Wallas thru hull fitting. Guess that heat or something else has created an unprotected area between hull and fitting so I want to take it out and re-install with a new batch of sealant. My question is what to use to re-calk the fitting. Does anyone know what the factory uses or even better what the Wallas folks recommend?
Thanks in advance for the input,
Tim
Tim
