Wanna put in a really big, comfy, ultra plush helm seat....but how?
skippythedog
Aug 28, 2025
1
....Not monstrously big like the crab boats on Deadliest Catch but at least something more plush, about the size of an automotive seat. (The real reason is that I'm a bit.....um chunky)....A nice seat with the ability to swivel maybe, would make the boat so much more usable but the stepped cabinet design totally precludes that. Yes the factory will build you a custom one but the other hangup I had was the lack of self bailing cockpit which I think I've solved by targeting 25'+ models (a 22 would be fine if it self bailed and had a comfy seat) but now we're approaching a quarter million.....I called the factory to see if they had measurements that would tell me if any older models had more belly room at the helm but they have no info at all on anything before the 2014 fire.....They didn't even have measurements on the current models that were designed before 2014...just the molds. Granted I haven't actually been aboard anything bigger than a 16' years ago, so I don't know what's possible modifying or moving the starboard side cabinet/heater.....I'd love some input from anyone that has addressed this or can provide some insight....Thanks.
You would be best served by seeing a boat in person--yes the Tom Cat 255 and C Dory 25 are self bailing--but the 255 has deck boxes which can leak into the bilge. The C Dory 25 has in the floor hatches, of which the factory hatches leak into the bilge. Some of these have been repaced with. hatch covers which do not leak. The older C Dory 25's had wooden furniture, and might slightly be easier to modify to make more room for the helm seat--many different types have been installed. You can certainly modify fiberglass interiors, but I feel that fabrication is a bit more difficult.
If you post your location, it is probable that there may be a C Dory 25 or Tom Cat 255 nearby that an owner will allow you to look at, and perhaps even take you on a trip---Where do you live? I was 6'2" and 180# and found the seat to be "comfortable, but at times I liked to run the boat standing up. My son has a 25 and he is 6'4" and in the 230 lb range--and can fit in the stock seat (1995 model). The largest bunk is in the Tom Cat 255 and is full beam athart ship.
Skippythedog,
I put a lot of time in the helm seat of my 26. After the first 100+ hours, I could no longer stand the existing seat and was willing to pay (almost anything) to have a comfortable seat. I spent a lot of time searching for a seat that would fit the space and not impact the pathway down the center of the boat. After extensive searching, I was about ready to have a seat custom made, or as a last resort, have my existing seat, redone with higher grade and custom cut foam. I had done this on my previous 22.
As I was about ready to redo the existing seat, I found a seat that fit the space, had a back that folded forward, has foam molded to fit your body, had a durable fabric cover and has armrest. I purchased the seat on eBay, but the seat can also be purchased at Tractor Supply.
About 400 hours of time on the new seat and I still am very happy with it.
Skippythedog,
Steve the seat looks pretty good overall, just wondering if 1: do you you the head rest at all and 2: if not could it be removed? Thanks.
I don't have a problem with the stock seat on my 22. However, I find the leg room lacking. I'm considering cutting out the lower part of the helm to make a foot box that extends into the storage space under the V-berth.
Hi Steve,
Manufacture of the seat?
Maybe I missed it. (Sure looks nice and comfy.)
Here is the link on eBay. The one at Tractor Supply was the same make and model, but it was not covered in cloth, which meant that it would have been too hot for me. The plus side of the one at TS, was that I was able to go to the store with my tape measure and ensure that it would fit.
The head rest likely could be removed.
I was able to increase my leg room by replacing the 15-16" wheel with an 11" wheel and a knob. It makes getting into and out of the helm seat much easier.
This is probably not exactly what you are looking for but I'm in the process of adding a shockwave suspension seat to my TC24. It's part of a larger update to the cabinetry but I think I can maintain the original size of the galley cabinet (temporarily replaced by a large aluminum box. I also made a new box to support the (rather large) manual honda throttle box since reverting from an earlier electronic throttle system. I've had back issues in the past and find the seat very comfortable for cruising around southern California. I ended up installing a swivel/slider too (not shockwave brand) and it's allowed the seat to turn 90deg for hanging out at anchor.
Steve,
I took your advice and bought one. I like it a lot, and it sure beats my 21 year old C-Dory original that had lost it's "lift".
Thanks.
Rod
