trpsurf
- Joined
- Oct 12, 2010
- Messages
- 111
- Reaction score
- 0
- C Dory Year
- 1997
- C Dory Model
- 24 Tomcat
- Vessel Name
- Oski
C-Brat Nation-
After an amazing year with our 22 Cruiser, we have discovered our first major issue, which forces us into “project mode.”
While coming home from Catalina on Friday, I discovered water seeping through a small hole in the area in the v-berth area under the porta potty. We quickly scapped our plans for the weekend and proceeded to pull the boat out of the water and drag it back home. Parking it in the drive way was no small feat, since the driveway is 9 feet wide and the trailer is 8’. Last year I installed a hitch on the front of my truck. It proved to be the best decision I have ever made.
Looking at the achieves here on the form, it seems like the likely culprit are the screws the brass keel guard. I cut two small holes in the v berth and quickly discovered that the foam is completely saturated. I used a shop vac to suck out about 2 gallons of water in not time. It is still wet under there and I will complete the process over the next week to get as much out as possible.
So here is the game plan:
1. Cut out and install v-berth storage hatches: I ordered the so-pac hatches that others here have used and will cut into the area, remove the foam, and create more storage space. We have been talking about this since we bought the boat and figure now is a great chance to tackle this project. Plus, I figure it will give us access to the inside of the leaking area. I know it is a horrible job, so I am not looking forward to the foam removal.
2. Fix the leak: (questions below).
3. Remodel the interior- I build furniture as a hobby, so I was thinking about additions such as a sliding, front facing seat, storage drawers under dinette seats. All of this will depend on how long the hatch/ leak project takes.
4. Freshen up the cockpit: build a flat floor, install two new bilge pumps, build under gunnel storage shelves.
Questions: Fixing the leaky brass keel protector:
Is it really as simple as removing the screws, filling with 5200, redrilling, and reinstalling? I was thinking that I would put 5200 on the inside as well, after the area has thoroughly dried out. Any lessons learned here would be greatly appreciated.
Should I install a Keel Guard- scrap the brass strip all together, leave the brass strip and install a Keel guard over the strip, or leave the brass strip and forget the Keel Guard? I see that several folks here have opted for the keel guard and have had positive results. Some of those threads are a few years old, so I am wondering how they have held up over time. I just had the bottom painted (since we put it in a slip a couple months back), so I will have to remove current paint and recoat in this area.
Any other recommendations on fixing the leak and protecting against water intrusion would be greatly appreciated.
I thoroughly appreciate all of the help.
Tim
C-Pelican
Tim
C-Pelican
