timflan
- Joined
- May 16, 2006
- Messages
- 550
- Reaction score
- 7
- C Dory Year
- 2005
- C Dory Model
- 22 Cruiser
- Vessel Name
- Two Lucky Fish +1
The water tank was almost empty, so I decided to empty it and run some water through it today. I wanted to get a better view of it, so I opened up the seat/locker that contains the tank.
There is a big piece of plywood installed over the water tank, and it closes off a chunk of potentially useful storage space. My questions:
Why is this plywood there at all? To protect it from puncture or abrasion that might occur if hard/sharp items were stored in that locker? To keep the tank in place in case the boat turns upside down, maybe? Those are the only explantions I can think of.
Can I remove it? Well, I already did. And I'm tempted to leave it out. The question is really: Do I need to put it back?
Has anyone modified this plywood? I'm thinking of cutting away the section nearest the hull, in order to gain access to this little cubby between the water tank and the hull. Then it would serve whatever its original purpose way, but I would gain a bit of storage.
Thanks, as usual!
Thanks, as usual!
