Well-known member
- Joined
- Oct 2, 2011
- Messages
- 5,132
- Reaction score
- 85
- C Dory Year
- 2009
- C Dory Model
- 25 Cruiser
- Hull Identification Number
- UWH25301J809
- Vessel Name
- C-Traveler
ssobol":1r9c9ilr said:You should consider that the combustion air inlet is about 1/4 the diameter of the ventilation air inlet. Assuming that the air velocities are the same, the combustion air is a fraction of the total air flow. I'm not sure that using an external source for the combustion air will make that much difference. All the Wallis installations on C-Dorys use the cabin air for combustion.
That is true, regarding the size of the air inlet. However, since that combustion air is being vented overboard out the exhaust, it does create a small suction, which will draw outside colder, (and moist in the case of fog and rain) air into the boat. The ventilation air is equalized with both it's intake and outflow inside the cabin.
