Wider sleeping area.
Conan2324
Mar 7, 2025
11
3
2019
nwm22co1d819
Norma Jean 2
I have a 2019 C dory 22 ft cruiser. Great boat but i can't sleep up front.
I sleep on the port side converter to a flat sleeping area but its only 28 inches wide.
Any suggestions on making the bed wider, would prefer 36 inches wide.
A board 6ft by 3 ft would work but where to store board when traveling.
Great trip last weekend Clinton, Iowa to Dubuque.
Thanks for any help
Assuming the 2019 is similar enough to the 2006 I had, you might be able to slide the bench seat and table 6 inches away from the port hull. It should “feel" much bigger and you have no extra part to store, except maybe an extra leg for supporting the table edge so it won’t flip if you sit on the very edge. I never tried it on the 22 but it does work on my TomCat.
I had the same problem with my 22' cruiser. My solution was two-fold. First, I purchased bunk board slats that were encased in a nonwoven fabric and cut them down to 36." By putting them all the way in, against the side, I ended up with a 30" platform (my comfort zone for width), since there is a 6" gap between the hull and the edge of the windows. The slats fold up for easy storage. To keep the slats from popping up when I sit on the edge, I cut pieces of wood to jam between the inside of the deck and the slats. Additional details for our comfort: I gradually tapered the boards down to 30" at my feet to increase the cabin space. I also added a bed rail at my head to keep me from rolling out, and to grab while getting in and out. The bed rail was held down with a screw and wing nut through the box under the seat. The cushions were placed on top of all this to make a 30" bunk that was 6' long.
OOPS. I posted the wrong picture for the bed rail. I got one that folds so it can be more easily stored.
I should also mention that I made my own cushions using different densities of 1" foam mattresses. The bench cushions are 3" thick for sitting and 30" wide. I also cut two additional layers of 1" foam that extend the full size of the bunk (30" at the head tapered to 24" at the foot). This allows me to sleep on 5" of foam; a lot more comfortable. The two top layers are covered with fabric, rolled during the day, and stored in the forward part. A 1" thick, twin size, piece of foam ranges from about $16 - $35 depending on density at https://www.foambymail.com/product/lux-r-foam-mattress.html . At this price we were able to buy several different densities of foam and experimented with different combinations of layers to find the best for each of us. My wife has a different combination of densities for her starboard berth than I do for the port side. The second picture shows the starboard side berth with one of the additional 1" mattress rolls.
The way I would handle this, is what I did in a Van Conversion which we did. I would make the dinette into a bench seat, with a fold out back to support the extra width of the bunk. 20" wide seat, and 20" wide back, folded down gives. you 40" and still enough to slide by when walking fore and aft. Issue is that you have to do something else for the table.
I am a fairly big guy at 6'2" and 185#. (those days, I shrank). My son is 6'4"+ and in the 235 to 250 range--and his (1995 25' CDory cruise ship) has the dinette which is 4' wide, with a narrower galley than the 22 or the later C Dory 25. I am not comfortable sleeping on the narrow dinette as it converts--but I have to make it do in some situations. What made the V bunk more comfortable for me, was that the port side bulkhead between the pilot house and the V berth was removed, so the port sleeping side of the V berth had cushions built to be flush with the V bunk, and became the part of the bunk where I put my head at night, so we could accommodate not only my wife Marie, and any number of the dogs we had during our ownership of C Dorys. (If we had more than one dog--the others had to sleep under the dinette table. Our poodle is not allowed on the bed while we are sleeping, but did sleep on top of the covers in the V Berth between us.
My concern with sleeping on the converted dinette is the possibility of ending up on the floor if the boat gets waked during the night. With the V-berth, you cannot fall out of it. I would be more comfortable sleeping on the cabin floor, rather than the converted dinette.
Sleeping on the floor works great if you are alone. Since there are two of us, and both of us often have to get up in the middle of the night, the floor is not an option. I find the bed rail works very well at keeping me on the bunk when the boat starts rocking. As mentioned the 25' has more options than the 22'. My wife and I tried lying in the V-berth but we found it would be impossible to get up in the middle of the night without waking the other person, and we kept bumping our heads when we tried to lie down or get up. With my spinal stenosis, getting in and out of the V berth also caused some pain.
I will try to get some pictures of my set up, and post them here.
Thank you for all the great ideas, I decided to go with the bunks slats, worked great.
Place 10 36 in bunk slats across, and a 6 ft 2x4 wedged in the port side to prevent tipping,
Then wedged in swim noodles to fill in gap.
Covered with an old blanket and placed cushions back on top.
Used 3 inch foam thermarest on top when sleeping.
Getting ready for Huck Finn trip, Prescot Wi down the MIssissippi to Clinton Ia.
6 days
Hoping for good weather and open Locks
Thanks again for all the help
Conan
I finally took some pictures of my bed slats with the bed rail and the storage for the additional 1" foam layers. The bed rail has a handy pocket to hold my watch and glasses.
Thank you for all the great ideas, ...
6 days
Conan
We have done from St. Croix confluence to the Illinois Confluence. Your stretch is about 300 miles, and that means hustling to make that 50 miles a day. There are lots of great towns along the way. "Meandering Notes of a Riverlorian", by Mike Link & Kate Crowley is certainly worth reading and using as you move along. There are a number of guides for car, but some of these are good for boating, since they are up to date, and have features in the little towns along the way. In Debuque, Iowa the Mississippi River Boat museum is worth a visit. There is a marine behind closed lock doors for times of flooding. Some other features close by, including a "shot tower". (molten lead is poured by hand from a height and it forms into lead shot on the way down.
Two "Google" rowing boats were moving at the same speed we were moving on one segment. They had a huge 360 degree camera taking photos (as they do from cars). They had started where there was just enough water to float the boats--and had to portage several places above Twin Cities. The crew had to sort thru over 4000 pictures each evening before transmitting tem to the photo division to make a river road map--I have never seen the finished product, but if available it might be a great resource. There can be fog in the mornings--we ran with our radar, but always at displacment speed. River boats don't stop for bad weather. Ais reciever is a real help here, and I would advise any one doing the river systems have this aboard. We have also done the St. John's, Cumberland and Tennessee River from navigable head to confluence. The C Dory is a excellent "river boat"
Enjoy and take lots of photos!
