Will an Intex Excursion 4 work as a tender for a 22 Cruiser?
benjaminrobinson
Nov 23, 2026
6
1
Location
Tulsa, Oklahoma
I have a 22 Cruiser and have been launching it on lakes by myself with a small trailer, and getting to shore has become a real hassle when I anchor out. I've been looking at the Intex Excursion 4 set as a cheap tender because it packs down small enough to store in the cabin, but I'm not sure it's up to being rowed or motored from an anchored boat. I usually have one adult and a dog aboard, and I'd only use it for short trips to a dock or beach. My concern is the vinyl and the oarlocks holding up to being dragged over the gunwale and pumped up repeatedly, plus whether it tracks well enough with the included oars in a light chop. Has anyone used one of these as a tender behind their C-Dory and found it workable for a season or two?
I have been using inflatable dinghies since 1962, This type of cheap boat will not last--and in some ways may be dangerous--in that trying to row it against a wind and chop may not be possible. There are PVC boats, such as the K boats, and heavier vinyl/pvc which will do for several years. A good PVC boat, such as an achillies will last many years. I had an inflatable Hypalon by Avon which was 25 years old and still going strong with one patch after 25 years.
If you were in water no more than your neck depth, and could establish an anchor on the beach, and one off the bow, to ferry gear and a few people ashore----it could be used farily safely (as long as no hypothermia etc risk.
The “K””Saturn” Bris/ Brig and similar are a couple of steps up. I have used mostly Avon’s, West Marine, Zodiac, and the higher end brands. My use has been hard, with an average of 3 to 4 trips ashore, in Alaska, Baltic, Med, Caribbean, S. Calif, Gulf Coast, and all along the Coast of N. America.
You can find 1100 wt pvc, with a 9 foot weight which is 70 lbs, and air floor which can be a decent boat; yet is small enough to put on the V berth forward.
I had a 13’ heavy duty inflatable Achillies, which was used daily for 4 years. For sharpo rocky shores, I suggest a RIB. Even with the fiberglass bottom, I put a saccraficical layer of epoxy and glass over the wear area of the “V” where the boat hit the beach, and the 90* bend at the transom, with a sacraficial layer applied each year.
If you are willing to pick up the boat, or have it on an “endless line” off the beach where it will never abraid on the rocks this can be done, if very careful.
I have an Intex Mariner 3 dinghy for my CD22. I don't actually use it that often. However, when I have used it, it works pretty well. It is better constructed than you'd expect. It can carry a pretty good load. When I bought mine you could get 4 or 5 of them for the price of a "regular" dinghy. You can get a motor mount to mount a small gas outboard or an electric trolling motor, but I have only ever rowed mine. The oars and oarlocks that come with the dinghy are fine for that application. Rowing any sort of similar style dinghy against the wind and/or current is going to be some work.
Usually the dinghy is stowed folded up until the first use on a trip. The dinghy can be initially inflated across the cockpit of the CD22. However, as inflation progresses, the dinghy gets too big for that area. Once the dinghy is partially inflated I put it on the water and finish inflating it from the swim step. The dinghy is either towed or placed inflated on the cabin top until it is determined that it will no longer be required on that trip.
The Mariner dinghys come (or came) with rod holders mounted on the top of the tubes. To store the dinghy inflated on the cabin roof it should be upside down to prevent it from filling with water if it rains. These rod holders are in the way of that so I cut them off.
The other thing is that the Mariner comes with inflatable cushions that are used as seats. These have a tendency to move around. I would suggest putting velco on the ends of the cushions and on the inside of the dinghy to keep the "seats" in place.
I think that the Mariner 4 is too big to use on a CD22. It is going to be hard to manage on a smaller boat. The Mariner 3 is a better choice. While it can carry less than the 4 is it easier to row and get on/off the C-Dory. If you have to, you might have to make additional trips to/from shore if you use the smaller dinghy.
IME, the Intex Mariner dinghies are perfectly fine for casual use. If you anticipate using the dinghy as a survival liferaft you might want to consider a more robust dinghy.
If you search YouTube you can find examples of people who have really tricked out the Mariner line of dinghies. Mostly as "fishing machines".
I have an Intex Mariner 3 dinghy for my CD22. I don't actually use it that often. However, when I have used it, it works pretty well. It is better constructed than you'd expect. It can carry a pretty good load.if you use the smaller dinghy...................
I am glad this works out for your purposes. I don’t see the issue as being the load, but the durability.
How well do the floors and “seats/cushions” of the Intrex hold up to dog’s claws? I have seen some of theses inflatables where they were schredded by dog’s claws.
We have considered our inflatable’s as life rafts, even on ocean crossings (having waterproof cover for our 13’ achillies, or 12.5 Avon RIB.) our 10’ hard dinghy would fit inside the achellies, and give a little more protection. Also survival gear (more than in a stardard life raft) were packed in the valese with the deflated dinghy. Not many C Dory’s carry regular life raft. The other issue with many life rafts, is that you are at the mercy of the wind and waves. A more robust craft you can row or even power toward a rescuue ship. There are many reports of sailors seeing a potential rescue vessel sailing right on by...it they had gotten even a could of miles closer, their distress signal most likely would have been seen.
I rescued 4 divers whose 13’ Boston Whaler had swamped with my inflatable dinghy---they had made their way to a small Island; all of the rocks at water line had barnacles which most likely would have punctured one of these cheap boats. Also note that the seams become unglued after about a year of being left out in the weather.---and I have seen failure at less exposure.
The dimensions of the 3 and 4:
"Capacity & Space: A 4-person model (such as the Intex Mariner 4) supports up to 1,100 lbs and measures roughly 129" x 57" x 19", whereas a 3-person model (such as the Intex Mariner 3) is rated for up to 880 lbs and measures around 9 ft 9 in long by 4 ft 2 in wide. Users on r/Inflataboats agree that 3-person boats can feel cramped with two people plus fishing gear, a cooler, and a battery."
My last quality PVC dinghy (Avon built & “West Marine” labled,--which I had used with 2 to 4 dogs aboard, also an air floor, and only 9.5 feet long) had been used for about 20 years on the various C Dorys I have owned. No failed seams. However these boat do present a danger towed, expecially if any wind or sea. I even managed to flip my 12.5’ RIB when towing--for tunately I had the motors off, and crab/shrimp pots well secured in. I was towing it at about 6 knots behind the Cal 46, a gust of wind caught it, an over it went. The lighter weight Imtex would flip much more easily in a seaway/wind. I aso agree that a 12’ 5” boat would be much harder to handle as a dinghy on a C Dory 22--it is certainly done. But it is nice to tuck the aft pontoons of a 9 1/2 inflatable under the rear radar arch, and then pass a line from hand rail to hand rail to secure the boat.
By the way, never travel with your inflatable boat fully inflated at high way speeds. One of my friends blew the entire bottom out of a very nice infltable dinghy doing that. You would be suprised how difficult it is to re glue the seams.
Don't know about the durability vs. dogs. Didn't take our dog on the dinghy. Probably depends on the size of the dog.
The mariner 3 is plenty big enough for two normal sized people and associated stuff when used as a transfer boat. I have even transferred some very big people with it. Since I don't use my dinghy for fishing, I can't comment on the space limits when used in that capacity. No matter what dinghy you use with a CD22, there is going to be a capacity limit you'll have to deal with. This is usually solved by multiple trips.
I wouldn’t recommend an Intex Excursion as a tender. The material is thin and vulnerable to puncture and abrasion, and the seams are prone to failure. I had an Intex inflatable kayak and my buddy had an Excursion, and they each lasted for 4 or 5 summers of occasional recreational use before they failed.
I’m not trashing them; we got a lot of use and enjoyment from our $100 inflatable boats. But I wouldn’t depend on one to get me from ship to shore; they’re not rugged enough.
