qboat
- Joined
- May 9, 2017
- Messages
- 69
- Reaction score
- 3
- C Dory Year
- 1993
- C Dory Model
- 22 Cruiser
- Vessel Name
- Runt
I have three "windows" to replace on Runt. One is the lens on the hatch--that came out easily. Second is the center forward window, which is fixed--I am going to put in a top-hinged window. I have not been able to remover it--I am having a heck of a time getting whatever it is bonded in to let go. I have looked through past posts, and see this is a common problem--If anyone has advice beyond driving in thin chisels around the outside and trying to pry it away, I would be grateful. Also, I make the fiberglass around the rough opening to be 1/4" thick. Is that right?
The third is the starboard sliding window, which is badly cracked. It is laminated glass. Thanks to past posts, I was able to get it out. But whatever the handle is glued on with, I am so far unable to persuade it to let go. Any suggestions?
Finally, assuming I do get the front window out without bending the frame too much, I will be happy to give it to any one who could use it.
Thanks! Sam
Thanks! Sam
